DR600GW-HD Solid Green / Frozen
Homac
DR600GW-HD
Recently I have noticed my DR600GW-HD is locking up / freezing. This will happen while driving, or when I enter the car and go to drive away (it does not commence recording from parking mode to normal recording).
Normally while recording I see the red flashing light and the blue GPS, however I can hear a soft click and then only a green solid light exists.
I have tried formatting the SD card on the unit and using the Blackvue computer application. Also tried using new and different capacity SD cards. Same issues, it eventually goes into the solid green mode and stops recording.
Any ideas would be appreciated.
Daywalker
BlackVue DR650GW-1CH
Went out to my car to pull the SD card out and noticed the blue led on. Wouldn't you know it it stopped recording at some point while I was out earlier that day.
Homac
Homac
DR600GW-HD
Not sure what you are suggesting. The blue light indicates the GPS is on.
Daywalker
Blue light/GPS should shut off when the vehicle isn't running.
