DR750LW - Blurred Front Camera
Ady_E
Perth Metro, Western Australia
Pittasoft BlackVue DR750-LW 2ch Full HD
Hi
As well as an issue of only 16Gb of a 64Gb Micro SD Card being recognised by the unit, it seems I also have a focus issue with the front camera.
I've only just noticed this as I hadn't viewed footage on a larger screen until yesterday.
As can be seen by the screenshot, objects in the distance are clearly out of focus.
Will I need to return this unit or can it easily be adjusted like on some of the older BlackVue models?
Thanks.
jokiin
Too many ¯\_(ツ)_/¯
get it swapped out under warranty, you'd void warranty if you open it up and start adjusting things yourself, not worthwhile
A
Ady_E
That's what I thought. I'll contact the seller and see how they want to play it. I don't want to have to remove and reinstall the entire installation just to replace the main unit.
evqevq
Singapore
Oh, I just got a replacement unit and has the same issue
evqevq
Singapore
Yes, can hardly see the plate of the vehicle in front of me.
dhavie
Metro Manila
Philippines
BlackVue DR750S-2CH, DR650S-2CH IR,
Send it back and demand answer. Very bad.
evqevq
Singapore
Yes very bad. In fact, this is the 2nd replacement unit.
my original unit failed during firmware upgrading, thus screwed up the firmware, couldn't start up. So i sent it in. Got a replacement (think it is a refurnished). This unit's touch screen failed after a few weeks. The image were also blurry. And I sent it in again. Current unit is the 2nd replacement.
I am from Singapore, the local agent does not bring in this model, thus I got it over the net. Seller is from Korea. Took me 1.5 months just to get the replacements. Their understanding of English is limited, very difficult to communicate with them on the issues I faced. The seller is responsive though.
evqevq
Singapore
get it replaced, check that it works ok, focus is good etc, then sell it on eBay
will get it replaced. If the replacement's focus is ok, may consider selling it too.
Got this last Jan. Got rear ended in last Feb & Apr. This cam saved me a lot of trouble when making the accident reports.
Anyway, any gd dual cam with full HD from other brands to recommend?
dhavie
Metro Manila
Philippines
Thinkware F750 looks promising
dhavie
Metro Manila
Philippines
Try to check out Thinkware X500 too. Not bad
jokiin
Too many ¯\_(ツ)_/¯
the Thinkware product is well made and stable, it's like most 2 channel product though in that the bitrate is low so video performance is ok but not fantastic, that's a chipset limitation though with current technology
