ECOFLOW and Viofo
Hi everyone,
Been going through a lot of threads but still not fully clear, so wanted to ask.
Setup
  • Toyota C-HR Hybrid (don’t want to touch factory wiring, afraid of messing with hybrid system and warranty issues)
  • EcoFlow River 3
  • Viofo A329
  • Considering Viofo HK4 / Viofo HK6
Goal
Fully isolated, plug & play. EcoFlow powers the cam, charges from 12V socket. No fuse tap, no grounding.
Issue
If I feed both ACC + BATT from EcoFlow, camera is basically always on.
After5 min - Parking mode is not reliable — sometimes it doesn’t exit when I start driving, transitions feel inconsistent.
Questions
  • Is there any clean way to get proper parking mode without tapping ACC? I’m not very familiar with ACC vs BATT wiring, just trying to understand what’s actually possible. I’d really prefer to avoid the fuse box (warranty concerns).
  • Does HK4/HK6 even make sense in this kind of setup without a real ACC signal?
  • I’m seriously considering the XT60 Y splitter, any real advantage?
What can i do as a complete newby?
I also watched Vortex radar video but couldn't find Xt60 - o ring wire available in my country. Any other recommendations?
Hi everyone,
Setup
  • EcoFlow River 3
  • Viofo A329
Goal
Issue
Questions
Welcome to DCT, @dopacan
Your goals are very reasonable (I really like that approach, too), and the EcoFlow River 3 is the ideal power station for use with dashcam.
To power the River 3, you will need an ACC cigarette lighter adapter (CLA) outlet; this same outlet can be used to supply the ACC signal, which along with the HK4 cable is required for the reliable Parking Mode operation.
See the attached wiring diagram for the RIVER 3.
You may also use the HK6 cable; however, voltage readings will be of no practical use in this instance, as the River 3 provides a constant, regulated voltage.
Nevertheless, with HK6, if desired, you may utilize a hybrid parking mode based on a time interval.
First of all, ensure that the ACC outlet in your vehicle - the one you plan to use - switches off immediately when the ignition is turned off.
The best way to obtain an ACC signal for connecting the yellow wire of the HK4 is to use an XT60 Y-splitter.
You need 1-male to 2-female splitter.
Here are some example links (make sure to select the correct one):
https://www.amazon.com/gp/B09L62W679
When using the RIVER 3, you have two connection options: via special USB-C to 15V cable or via Ecoflow's 12V cigarette lighter port - provided that the "Port Memory" feature is enabled in the EcoFlow settings.
USB-C to 15V cable
or
12V Car Cigarette Lighter Plug with wires
https://www.amazon.com/gp/B0963QJLRG
For reference, you may also check the following posts out in this thread: Post# 26, 57, 166, and 167.
There are a several ways how the River2 can be wired, with 12V out or 5V out to DashCam.
My preferred method would be 12V out like shown in attached diagram below.
In this case original HK4 can be used as is.
Use included Cig adapter/XT60 cable to charge River2 from car’s ACC activated Cig socket. (Make sure it is rated for 10A (the fuse is usually 20A for these sockets).
Splice yellow trigger wire (18-20AWG) with positive wire of the included Cig adapter/XT60 cable or use splitter like one in the link below, connect the included charging cable to one barrel and cut-off the other barrel and use positive 12V wire for the yellow trigger wire. (tape and do not use negative wire).
https://www.amazon.com/gp/B08CMT94CV
Get USB-C to 12V cable, similar to one in the link, and cut-off the barrel connector, to connect positive wire to Red and negative to Black wires of the HK4 to power DashCam. (15V cable provides better margin for 11.8V min setting of HK4 and may be better, but I am not sure without testing).
https://www.amazon.com/gp/B0CDFWRZB7
If you don’t have 10A rated ACC activated Cig socket you can similarly wire and charge form the fuse box (for the long wires 14 or better 12AWG wires would be needed) since River 2 charge rate using 12VDC is about 90-100W)
I think this should work unless I'm missing something.
EDIT: See post #57 for the video showing how this wiring works, and also for option to use USB-A to 12V converter cable, if USB-C cable requires unplugging and re-plugging to activate
GPak
EDIT 2: USB-C to 12V or 15V cable works well with River 2, it does not require unplugging/re-plugging routine and is more efficient option compere to USB-A to 12V converter cable.
GPak
Hi,
I have Ecoflow 3 PLUS and Viofo A229 PLUS.
Quick 2 questions:
1. What USB-C -> USB-C cable should I use for power my VIOFO A229 PLUS? Asking because I need min 6 meters of this power cable. I had try many 6m-8m USB-C cables, but Viofo cycle power and not working correctly.
2. As I saw Ecoflow 3 PLUS not remeber cigarette port state even if at the app was set to remember.....
KA
Hi,
Quick 2 questions:
KA
@sysio2000
Are you using an HK4 or HK6 hardwire kit, or are you powering the A229 Plus directly - without using a hardwire kit?
If you are using the HK4 or HK6, all the necessary information is contained in my previous post - including a link to a USB-C to 15V cable (or buy a similar USB-C to 15V cable available in Poland).
If you wish to connect the A229 Plus directly (without the HK4 or HK6), it is best to use the included cigarette lighter adapter (CLA) and the bundled USB-C cable.
This will provide about 5.2V neccesery to power the A229 Plus.
Connect the included CLA and USB-C cable to the EcoFlow 12V cigarette lighter socket to power the dash cam.
Turn DC ON and Enable the "Port Memory" feature in the EcoFlow settings.
Your dashcam will start up and function normally.
If the included cable is too short, you may need to splice/extend it using 18 AWG wires - or even 16 AWG for a really long cable.
Alternatively, you can contact Viofo Support and request a longer cable (Viofo is typically accommodating when it comes to providing cables of non-standard lengths).
NOTE: Standard USB-C to USB-C cables do not work with Viofo dashcams and most other brand dashcams, as their USB-C port is merely a "dumb" connector incapable of negotiating the required voltage.
I own both the River3 and the River3+.
It has been quite a while since I tested them, but I recall that both models respect the "Port Memory ON" setting - with the possible exception when the Ecoflow is completely depleted; in such a situation, you might have to wait a few minutes after recharging begins, or manually enable the DC output.
However, here is an Option 2:
You can use the below linked cable (or similar available in Poland or AliExpress), with Viofo included CLA adapter and cable
Option 2 Cable
NOTE: As I mentioned earlier, the Viofo dashcam requires a stable voltage of 5–5.5V at the dashcam input.
@sysio2000
Thanks for answer 🙂 I have to think about the way I choose to power my Viofo 🙂
KA
Option 2 Cable
Ok.
I had done some tests 🙂
It looks like when Ecoflow R3+ battery discharge to 0%, even if "Port Memory On" is set, the power at the cigarette output occur when battery will be charged to min 5%. I took approx 10-11 min with home charging (at the car even more).
(the same situation with USB-C output).
Unfortunatelly 10 min (or more) Viofo start recording delay time isn't acceptable to use it for dash cam 🙁
I have to figure-out how to set the Ecoflow settings to:
1. Power my VIOFO from Ecoflow at the beggining of engine start (acceptable delay - max 2-3 minutes).
2. Set max discharge Ecoflow battery to level, that after next morning engine start, Viofo start recording in max 2 minutes 🙂
Maybe you have some hint?
KA
Ok.
KA
My EcoFlow River 3 worked in my car for over a year, and during that entire time, I never once managed to drain it completely - even though the geofencing feature was not yet available at the time.
Nevertheless,
The issue of power supply delay - which occurs when the power station runs out of charge can be resolved using a "Dual Power Transfer Switch" module, or, simply put, a UPS.
In fact, this is my preferred method powering my dashcams: all of my DIY dedicated LTO batteries are equipped with built-in UPS functionality.
(You can find the corresponding thread dedicated to LTO right here on DCT).
The UPS module mentioned in the link is a ready-to-use, plug-and-play solution for "12V' systems (no adjustment is needed);
It is rated for up to 8A - which is more than sufficient to power any dashcam.
https://www.aliexpress.us/item/3256809434821322.html?spm=a2g0o.tesla.0.0.6ea4w7vvw7vvl3&pdp_npi=6@dis!USD!$10.02!$4.02!!!!!@2101e2b617765394365618777eb82f!12000049659151152!btfpre!!!!1!0!&pvid=5973036d-80a0-4cf5-81e6-5fc871730abe&afTraceInfo=1005009621136074__pc__c_ppc_item_bridge_pc_main__vS1GNy0__1776539436639&gatewayAdapt=glo2usa4itemAdapt
Attached is a wiring block diagram.
And here is the video to demonstrate how it operates.
EDIT: plain XT60 charging cable and XT60 Y-splitter work with River3 Plus (ref. post # 293)
My EcoFlow River 3 worker in my car for over a year, and during that entire time, I never once managed to drain it completely - even though the geofencing feature was not yet available at the time.
Nevertheless,
Great!
That is what I need ! Many thanks 🙂
KA
Nevertheless,
I will attempt this soon. This amazon link appears to be the same item, correct? https://tinyurl.com/2j7c79f7
Nevertheless,
Thank you for all the detailed information. I am going to use this setup in my car and I have one question. I have the river 3 plus like you have in the video and I wanted to know what power cord you are using to connect it to the cars 12v port. The power cable that comes with the River 3 plus isn't a standard red/black cable and I can't splice into it (or at least I don't have the skills to).
I saw you linked the 12V Car Cigarette Lighter Plug with wires. Is this what you are using or something different? If you are using this, do the metal ends plug directly into the river 3 plus or is there another connector in-between?
Just in time: I posted another video on this topic in a parallel thread, and I’ll copy it over here now.
You won't need that 12-volt cable you mentioned.
Power the River 3+ using the original charging cable and an XT60 Y-splitter (links can be found in Post #282; I’ll also attach an image here so you know exactly which splitter I’m referring to, should you decide to order it from AliExpress).
Use the 15V USB-C cable linked in Post #282 (you’ll need to cut off the round barrel plug to access the red and black wires, see attachment).
Make the connections exactly as shown in Post #282 attachment and in this video:
I actually have a splitter on hand so that makes this a lot easier. Thanks. Now I just have to wait for the UPS to arrive.
Which Dashcam are you using?
If it is not Viofo, you need to see this post:
I am using a Vantrue dashcam. So if I wanted the UPS to work properly with a dashcam that is not a Viofo, I will have to add a relay? What is the reason the phantom volts affect other dashcams but not Viofo?
The main reason I wanted a UPS was so I don't get the long delay on startup when the river 3 plus battery is dead. I want the camera to start up automatically when the car starts regardless of the state of the battery. In my case, is the relay still necessary?
Hi I have R3+ and I decide to not use ST60 Y splitter because R3+ have third pin for info regarding typy of connection. Chat GPT gave me info, that this is not the best idea. Then I had decide to but Cigarette light adapter splitter to 2 sources. In 1 source I connect oruginal R3+ car charging cable, and to 2 source I connect to "Dual Power Transfer Switch" (as GPac suggest). That connection working ok and I can move R3+ for another car and use stock car charging cable without any cut the etc.
KA
GPak
I have quick question regarding the power drain durring idle at R3+.
My setup:
1. Viofo A229 Plus (front and rear camera)
2. HK4 Adaptec (USB-C)
3. Cigarette spliter (1 male -> 2 female)
4. USB-C to 15V cable
5. "Dual Power Transfer Switch"
R3+ settings:
6. Car input charge - 6A
7. DC - automatic
8. Port memory ON.
9. Charging limits - 0%-100%
10. Reservation - Disabled
11. Wif enabled
12. Bluetooth enabled
Connections:
- Viofo connect using USB-C (using USB-c->15V cable) -> "Dual Power Transfer Switch" -> HK4 ->Viofo
- Original Car cigarette charging port-> Car cigarette charging splitter (1 male-> 2 female)-> 1-st female-> R3+ connected using stock car XT60i cable
Questions:
Q1: Is it possible to minimize the power drain of R3+? (Wifi disable for example)?
Q2. How to disable Bluetooth at all? Maybe this will be usefull to minimize power drain?
maybe you have some usefull tips 🙂
thanks 🙂
Sysio2000
We have never previously discussed Vantrue and Ecoflow River compatibility.
Does Vantrue work with River 3 Plus (without UPS) and does it switch into parking mode and back to normal mode without any issues?
If so, please let at us now for the future reference.
If Vantrue functions correctly (switching between modes) without a UPS, it will certainly work with the UPS as well - In this case a Relay is NOT needed.
In fact the UPS has nothing to do with the ACC signal responsible for switching between modes, as that signal bypasses the UPS entirely.
A relay, conversely, is necessary solely for managing the ACC signal when used with specific dashcam models, regardless of UPS.
As of now, this list includes Thinkware, BlackVue, and Red Tiger.
My guess would be - the sensitivity to ACC signal voltage.
Viofo probably needs at list 5V to register the ACC signal, whereas other dashcam brands may have lower voltage requirements for ACC signal.
That is exactly what a UPS is for!
As I mentioned above, if the Vantrue operates properly without a UPS, then the Relay is NOT required—neither with a UPS nor without one.
KA
The way you wired is perfectly fine!
That is exactly how I connected my power stations previously.
On charging cables/connectors:
The third pin in XT60I connector is to identify the power source and properly limit the max charging current.
With car charging via CLA the third pin and positive pin are interconnected, limiting the max charging current to up to 8A (to protect CLA circuity).
With Solar charging the third pin and negative pin are interconnected, allowing up to 13A charging.
When using plain two-pin XT60 the Ecoflow defaults to lower up to 8A charging limit for safety.
I have tested this and can confirm it.
Consequently, in my opinion, using a standard XT60 connector in conjunction with a splitter is safe.
