Has anyone experienced locked Event files missing when the SD card is connected to a PC? It's a VanTrue S1, but I'm sure a lot of dashcams have a similar set up where there's supposed to be a separate folder for Event footage. My father was in an accident yesterday and when I walked him through hooking up his SD card to his laptop there was only a folder (called Normal) with the regular footage, and it had clips before and after the accident. When I hook mine up I can see 3 folders, including Events. I'm sure the accident file is somewhere since it was suspiciously missing from Normal, but I'm not sure how to troubleshoot finding it... Any ideas?
Welcome to the forum
@jenthescient1st neat profile name.
I have a Vanture S2 so I can't replicate exactly the S1 but I would expect they are similar.
I formatted a card and recorded some video when I plugged the S2 into my computer via a data cable I only saw the Normal folder.
I then removed the data cable and just powered up the dashcam as it would be in a car and created some collision movements.
I noticed two things,
1. If the dashcam has low power supply it will reboot and not create the incident or the Event folder.
2. With the collision detection on its highest settings which is 5 and bumping the dashcam in up. down. and side to side it created an event folder and had those files in it. Viewed from the 3" screen that is on this unit.
To confirm this I then reconnected the dashcam to the computer via a data cable and opened up windows explorer and found the second folder called Event with the files that were created by bumping the unit.
Was the impact sufficient to have triggered the Event folder to be created? Is the dashcam settings for impact set to high or low?
If the file was deleted accidentally or the event folder, it is possible to recover these potential lost files providing the memory card is no longer in use. It is still in use there is a chance the file/s has been overwritten.
Recovery of lost files. Here is a link to a product I use occasionally.
EaseUS free data recovery software can help recover data after accident deletion, formatting, partition error, system crash etc. Free download data recovery software and follow the guide to recover lost files from PCs, laptops or removable devices in Windows 11/10/8.1/7.
www.easeus.com
There are plenty of others out there if this one is not suitable.
Hope this helps.
Cheers.
