external power supply problem
Keep me posted and God's speed!
Errr, what for?šŸ˜•
It's @GJHS who needs the thanks.šŸ˜›
What was the result of the h2wtest.exe on the microSD card?
I'm still thinking that the microSD card might be the problem (fake or compatibility issue) as there's nothing fundamentally wrong with the settings you have used.
I agree with @GJHS updating to FW 2.10 is a good idea. Can't remember if FW 1.17 had some card compatibility issues or not...
Is the 'SYSCFG.TXT ' file still visible on your card once you've finished updating your settings?
As promised yesterday, here is the operation report:
I inserted a thin strip of clear tape into the center of the wider cable connector.
Plugged it and the transformer into the wall outlet, micro end into the camera, then turned on to record video.
Camera stopped recording after 1½ hours.
Result:
21.4 GB free of 29.7 GB
recorded 19 5 min. clips from 9:43 to 11:13 A.M.
Analysis: no improvement.
Because of possible misplacement of clear tape I shall try to redo this process.
h2wtest.exe
It is still 'veryfying'!
How do I update to FW2.10? When I ask in the tools folder the to check on new firmware it simply says that no new FW is found online!
Where do I find this? After formatting the card is just empty.
Here is the result:
You're doing this check with the camera plugged in and selected?
Here is the result:
Why did it only test part of the whole memory?
Sorry about my late response, I've been away all day
Yes.
I thought it may be because it only checked the used memory and not the free space?
Hell, inexcusable!!! šŸ˜› Glad you are back!
Time to take it up a notch. @Isoprop what are we missing? I think it's that cable. Try running the camera on battery power and see if it goes the full hour+ until the battery runs out
@Alfred you did get the GUI here right?
http://www.mytempfiles.info/mobius/
The SYSCFG.TXT file is written onto the microSD card to enable setting changes to be made and saved back to the Mobius once those setting have been altered. The GUI (msetup.exe) should be doing this for you. If you format the card each time there is no way of knowing if this process is happening correctly.
I was asking to make sure that that file wasn't still on your microSD card, i.e., your setting changes may not have been saved back to the Mobius. When you open up GUI with your Mobius attached are your previous settings there?
That h2wtest.exe result is a little odd. Please can you format the card and run the test again?
Your earlier screen shot shows a card with 7.27 GB in total. Is that the same card??
Just to avoid any misunderstanding, mSetup never connects to the Mobius' file system unless it's updating the firmware. Formatting the card and setting/reading the parameters is done entirely using USB communication.
It's unimportant if a SYSCFG.TXT file is on the card or not, mSetup will always ignore it. When using Windows together with mSetup it is never necessary to create a SYSCFG.TXT file.
The SYSCFG.TXT file is useful for Mac and Linux users but can also be used by Windows users if they prefer doing things the hard (and error prone) way. The configuration file is a universal method for reading, setting and exchanging the Mobius' parameters. It works on all computer systems which support SD cards.
Since you've been following up on this issue I've lost track, I'm afraid. I've skimmed over the messages and also suspect the cable.
The easiest way to check would be to remove the battery altogether and use USB power only. If recording stops after about an hour, then it's almost certainly a card problem. I say 'almost' because the problem may only occur when the battery is installed. In this case the Mobius will draw more power from the charger which could cause it to fail. As a side effect, using the camera without a battery installed will ensure the camera is turned on before recording is started.
Remember to stop your recording manually. The last clip will not be saved if power is cut.
h2testw should only be run when the card has been freshly formatted. A positive result does not guarantee the card will work properly in the Mobius. All it does is guarantee the card isn't a marked up fake. h2testw cannot test for card controller timing issues.
I think so, but will upload a screenshot to make you see it:
I will do that now and report after lunch!
That was with the original 8GB card inserted, while I was testing the 32 GB one separately.
If the "Check" button is pressed in the "Tools" dialog then at least one firmware version should be found. If not, there is most likely an internet connection problem. Make sure your camera is selected before opening the "Tools" dialog. In your above screenshot you haven't done this.
I did it right now to show you the screenshot:
