external power supply problem
If the "Check" button is pressed in the "Tools" dialog then at least one firmware version should be found. If not, there is most likely an internet connection problem. Make sure your camera is selected before opening the "Tools" dialog. In your above screenshot you haven't done this.
I did it right now to show you the screenshot:
The GUI should find the firmware. If it doesn't, then for some reason it can't connect to the internet. Very likely it's a firewall issue. You may have replied NO the first time you launched the program when asked if you trust the program.
Here are some other ideas that may function as a work-around until you've fixed your firewall settings.
From your screen shot it appears that you could be running the program from a Windows protected folder (c:\program files or similar).
Copy mSetup to a new folder or directly to the root. For example, copy mSetup to d: or to c:\Mobius etc.
You may also need to run mSetup as Administrator (right click the program).
Just to avoid any misunderstanding, mSetup never connects to the Mobius' file system unless it's updating the firmware. Formatting the card and setting/reading the parameters is done entirely using USB communication.
It's unimportant if a SYSCFG.TXT file is on the card or not, mSetup will always ignore it. When using Windows together with mSetup it is never necessary to create a SYSCFG.TXT file.
The SYSCFG.TXT file is useful for Mac and Linux users but can also be used by Windows users if they prefer doing things the hard (and error prone) way. The configuration file is a universal method for reading, setting and exchanging the Mobius' parameters. It works on all computer systems which support SD cards.
Thanks for clearing up my massive misunderstanding! I'm a muppet for assuming mSetup did setting changes in the same way as the Apple Mobius GUI!
@Alfred - apologies for any confusion I've caused you.
I've given myself five hefty lashes & been sent to the bottom of the class!😉
Well, I am an easy target for confusion anyway...
What I have done all day so far was doing that darn 10-hour chip test, to prove what I thought worked fine anyway.
(and I don't know what I should do next!)
Ok let's do this. I, as well as Master Isoprop think it's the cable you're using. Let's test it by opening the case and removing the battery. Here are the directions, it's really simply, just be really careful not to touch the ribbon cable to the lens.
Then try recording using only the camera connected to usb power, without the battery and see if the card fills.
You may not believe this, but I actually got that battery out! 😀
I suppose you meant connecting to the external power supply via the 6 foot cable, which we suspect to be a data cable, right?
Right
Ok, here is what's happening:
On the USB port from my PC via the short cable I can turn the camera on and off, but only the yellow light comes on blinking.
Going to the external 110V power supply via the questionable 6-foot cable (which I have taped up inside the wide connector), I only get the blue light blinking slowly, and can't turn it on and off. Same thing when I remove the tapes inside the connector. 😳
Ok yellow blinking means it's recording. Does it stay recording until the card is full or turn off early as before?
Correction to aforesaid:
There was no free space on the card when all that blinking went on, because the card was loaded with the result files of the chip test. After formatting it I can turn it on and off, but only a yellow light comes on, without blinking.
Press the shutter button to start recording. If it won't record then it's the cable
It does not react to either mode or shutter buttons, with either cable and either power supply.
That would indicate that it's a data cable. Neither cable will record?
That is affirmative, and our clear tape trick doesn't fool them either! Trouble is that all the power type cables I see have pin connectors.
Well at least you know what the problem is. Time to go cable shopping or just buy the Mobius power cable
Here or Amazon
Here or Amazon
Well, there it is, Thank you both very much for your patience! Funny thing is that originally I had made an inquiry at the Mobius site for those eternal power supply items and was told they don't have them!
The place I gave you is an authorized reseller and someone who really knows this camera. Another would be SpyTec
The specs explain that it is a charging cable, not for data - which is what we needed. But will it keep supplying power while recording?
What he said 😀
