Its the usb port.
When I wobble the connector the screen flickers and sometimes it switches off.
Other cables wobble as well.
Can I try to bend the port a bit to make the fit tight or what other trics are there? Small layer of soldering?
maybe its the way you have it mounted in that convertible of yours, the wires are just hanging there?? or are they attached somewhere so the wires arent pulling on the unit making the connection loose?? maybe need to attach the wires at the top of the screen or something so every bump you go over doesnt pull on the cable.
Looks like it. Didn't have trouble with the V2 though.the cables just hanging like that might not do the port any favours over the long term
The wires are hanging but only about 30 cm.maybe its the way you have it mounted in that convertible of yours, the wires are just hanging there?? or are they attached somewhere so the wires arent pulling on the unit making the connection loose??
Yes it is.is that the one that @niko opened up before
What narrow part?I would try and pinch the USB plug a little tiny bit on the narrow part, very little at the time proceed careful.
Solder a drop on the male part of power cable to make a really snug fit or try to gently spread open the male connector Force something in male opening to spread it a bit more open Crude but works I did that and it fits tight nowIts the usb port.
I imgine something like this:If you look inside the connectors and see how the contacts mate it becomes clear where and how to bend the plug
And it keeps doing that when I pinch.It wobbles from side to side, not front to back.
Wow!
This is the V2.
Every file on that trip does this. After a few seconds it's just noise!
