W Google Play jest tylko App 1.2.0 Firmware nie maApp version - 1.2.0
Firmware ver. 1.0.5
Available at Google Play.
Thank you very much. Could you explain new feature with this new firmware ?There are problems with updating english firmware 1.04na to 1.05na via OTA. I did it manually, here is the LINK to firmware file.
1. unpack zip
2. put whole "update" folder into root of sdcard
3. while holding the 4th button (1st from the right) press the long button, wait for camera turning on and update message
4. wait some 20 sec. until screen goes out.
5. delete "update" folder from sdcard
No problems after update card is readable and recordings are downloading fine to the phone.Does anyone have a problem after update the firmware?
but they did it in the worst possible way.
Gps data is added only in-app preview if you open it in other player data overlay is missing.
thanksThere are problems with updating english firmware 1.04na to 1.05na via OTA. I did it manually, here is the LINK to firmware file.
1. unpack zip
I want the speed to show up as color as the day without gps thankThere are problems with updating english firmware 1.04na to 1.05na via OTA. I did it manually, here is the LINK to firmware file.
1. unpack zip
Are you sure that folder "update" should be placed in root? Not its content? Because update process is failed.There are problems with updating english firmware 1.04na to 1.05na via OTA. I did it manually, here is the LINK to firmware file.
1. unpack zip
You should format your micro sd card with 70MaiPro first, then copy update folder(and everything inside that) from zipfile to root of card(do not let Windows/OS do anything with your card, some system show that need to fix drive just ignore it)Are you sure that folder "update" should be placed in root? Not its content? Because update process is failed.
