I prefer to use 30fps all time. I need to find where is the problem.Be sure front camera isn't set to 60fps.
App is updated from the app store for your phone.I prefer to use 30fps all time. I need to find where is the problem.
I found an issue. In the APP I don't have HDR switch only WDR but in the dash cam menu it exists and has 3 options: off/on/timer. I turn on the timer and will have a look at how it works. Also maybe somebody can help with a better resolution? 2560*1440 30fps is the best idea to use? I see somebody using 1440*1080 for better sharpness. Does HDR work better in 30fps or in 60fps?App is updated from the app store for your phone.
HDR can only work with 30fps. Update your app and firmware (if needed) and you'll likely see the HDR option.I found an issue. In the APP I don't have HDR switch only WDR but in the dash cam menu it exists and has 3 options: off/on/timer. I turn on the timer and will have a look at how it works. Also maybe somebody can help with a better resolution? 2560*1440 30fps is the best idea to use? I see somebody using 1440*1080 for better sharpness. Does HDR work better in 30fps or in 60fps?
