DeLorean
- Mar 26, 2013
- HM Prison Wormwood Scrubs
- United Kingdom
- Front: G90 A7LA70 with GPS / Rear: G1WH
Hi Guys,
I have a G1WH that utilises the new GeneralPlus GPCV2159 processor.
I've opened the camera to verify the processor as flashing it with a firmware for a Novatek model would most probably brick it.
It was shipped with firmware version G1WHT-301-150810V01LD which absolutely sucks.
After running continuously for a few days the camera will just stop recording and refuse to power cycle correctly.
Using the power button to switch the camera off and back on will set it rolling for a few more days until the same thing happens.
It happens like clockwork every 2 days so it's got to be a firmware issue.
Does anyone know which other firmware can be used for these GPCV2159 powered cameras?
Also, can you back up the firmware on these unit prior to flashing another?
I'd just like to have a copy if it's current G1WHT-301-150810V01LD firmware should I run into problems.
Thanks very much
For a cheap camera the internal build is not bad and the video quality (day & night) is very good. The housing and mount on the other hand are absolute crap which makes opening it up a breeze by just using your finger nails
Thanks very much
