Fix invalid SN "language adaptation error" - pink screen
kamaov
Czech Republic
Dzienkuje za info i pomoc...
kokoaung
Myanmar
For fix this is only one way (╯︵╰,).
For people from europe: people who are interested send camera to me for repair please write to my e-mail dwro(dot)ddr(at)gmail(dot)com. Repair cost 50 PLN, shipping outside my country around 20 PLN.
This solution works with all yi dash models.
Connect to UART port on mainboard. Remember to connect GND too.
If you're using arduino as adapter then short RESET to GND for bypass uC and connect RX -> UART RX, TX -> UART TX. If USB UART adapter then connect RX -> UART TX, TX -> UART RX.
Chinese arduino with CH340T and etc. (not atmega8 programmer) probably won't work as adapter.
Connect to adapter using putty with baud rate 115200. I'm using linux and for me device is listed as /dev/ttyACM0.
If no error then adapter connected succesfully. Plug power cable and you will see booting messages.
Type "netcar sn yourserialnumber" (command with small letters, serial number with big letters) and press enter.
And voilea.
Problem solved.
Now i have this step...
How to type SN in putty
Helpme,Sir
shironator
Slovakia
I read that in putty settings, you need to set those. And then you should see what youre typing into command line.
