Re: G1W Novatek 96650 WDR F1.6 H.264 MOV 15Mbps GPS Dash Cam
I bought 4 pieces g1w at saddles, each for 60$ inclusive free shipping to germany, for my family cars
Before i owned 2 cheap fake dvr007...well at night not much was visible...in daylight enough to see what happened without many details :lol: and they cost here in germany 35€...very expensive...well they were my first ones, and advertised as 720p...and i had to start with something... in germany you can unfortunately buy only crap dvr for alot of cash...
I wanna thank you guys here on this forum and specially on this thread, for your testing an information you provided on this camera and saddle, it helped me really a lot...without you i wouldnt have found and bought it.(too huge risk for fake ripoff :mrgreen: )
In my opinion this camera has a good price/worth relation... gt300w was the next one but with 80$ per piece it would be 80$ more for 4 pieces...an you have to pay additional 20% customs on arrival for all...the decision was rather economic rational :roll: The other candidate was gw2, but there was absolutely nearly none information and experiences about it on the web, so i passed and took g1w.
Considering that this camera will be hanging around all year in the car in cold and hot wetter, maybe fall off from the window...and die because of the heat, cold or fall impact...or even because it was produced the chinese way... and to use quarantee you have to send it to china for shipping costs that amount to camera costs....to invest alot was out of question
So now to my experience, on daylight excelent camera, good hd videos. In the night there is some white noise mixed...but still video is good....really superior to the usual crap in germany. Because of the noise in night videos, definitely not comparable to gt300w. But still more than worth its money.
I was also able to flash gt300w firmware on g1w by coincidence, the "201306180-SC-2" one, you can find it in this thread, didnt experiment with the other older or newer ones there...may work too, i dont want to brick it yet :mrgreen:
http://dashcamtalk.com/forum/viewtopic.php?f=29&t=1778&start
Just rename the firmware file to FW96650A.bin and follow the same procedure as described in that thread for gt300w (put it on your empty sd card direct in the root, and start camera....it will flash itself...quite easy....)
WARNING!!! DO IT ON YOU OWN RISK...YOU COULD BRICK IT IF SOMETHING WENT WRONG, OR IF FIRMWARE IS INCOMPATIBLE
IT SEEMS NO ONE REALLY KNOWS WHICH FIRMWARE MAY BE COMPATIBLE AND WHICH ONE NOT...AND THERE SEEMS TO BE NO FLASHBACK
ONCE YOU FLASH YOU CAN NOT RETURN TO OLD G1W FIRMWARE
So why did i risk to brick it by flashing...well...i was just curious and a bit stupid.. i had a problem with one of my my DVR which i thought was the firmware so i took the risk....sending it back was expensive so that it wouldnt matter if i bricked it
My DVR would freeze and restart, before it restarted the display was getting brighter and then after a second dimmer, this repeated for some time until it restarted, in reality the problem was my USB POWER DAPTER, not the original that came with teh camera but my own one, that should have provided 2A but in reality was cheap crap that could hold these 2A only for like 10 minutes...that was the real cause, but i suspected the firmware and took the risk to flash...
Another problem with original g1w firmware was that other loop recording as 3min loops didnt work properly, sometimes the loop would just stop recording... i didnt know at that time that this problem could be solved by setting the loop time to 3min.... :mrgreen:
And so i flashed....and i didnt regret it until now :lol:
Some functionality of the original g1w firmware will be LOST forever(instant on when power on, some languages translation, setting for working time after power off, etc...unfortunately i didnt write all of them them down and didnt made a comparison) and some will be different(needs 2-3 seconds for turn on and start record when power on, only 3 min loop record works properly, <-but in my experience this was also the case with g1w firmware)...but you will have AWB and a slightly better video quality.
The recording in loop will only work for 3min loop properly, other setting will result in stop of recording when the sd card is full
This forum helped me alot to pinpoint the settings that worked....seems there are other having troubles with different settings...so this is not purely a g1w problem
Well i flashed all of my 4 cameras with the gt300w firmware and i like it better this way
I use 16gb and 32gb class 10 Transcend sd cards...work like a charm since i figured out that only the 3min loop works properly
thats my 2cents... i hope this helps someone like it did me
