- May 1, 2013
- Dublin
- Ireland
Well now I'm just confused... so you can hardwire the cam, or you can't? You just say in the same post that you both can and can't. Or do you mean you can hardwire it, as long as you remove the battery (in which case, why would you hardwire it without taking the battery out?).
I know a cig lighter socket will do the auto start/stop/motion, but as I understand, hardwiring is essentially doing a more-permanent version of a cig lighter socket.
Ah, okay. Thanks. So basically... 1 is just #2 where you remove the battery?
You do not need to remove battery from dash cam. As I wrote, - if you plan to have dash camera constantly working for parking motion detection, - it is not a good idea to buy dash cams with batteries inside. For this you need dash cameras with capacitors adn hardwire directly to constant 12v ( battery )
FOr normal every-day use for start and stop you can hardwire to fuse box ACC ( ignition fuse ).
