McBain
- Oct 22, 2013
- Dallas, TX
- G1W
I got a 32Gb Kingston class 4 SD card for the G1W. Does anyone think this might be too slow or should it work?
i would give it a test around the block and just check to make sure there are no gaps or sluggish video. I can't speak for the G1W, but i had to use a Class 4 Sandisk SD card in a DVR-027.I got a 32Gb Kingston class 4 SD card for the G1W. Does anyone think this might be too slow or should it work?
Since I'm still waiting on delivery, does it format the SD card for you or do you have to format it on your computer first?
I believe the GS9000L is a knock off of the Ambarella version without the L (Same with the GS8000/L) I can not find a spec sheet on the GS900L, but the GS8000L is not recommended according to the FAQ posted, and i am assuming they run the same chip. When buying a Novatek chip camera if the chip is not 96650 you will most likely be disappointed by the video quality.I'm about to buy the G1W by price / performance and I find this new GS9000L for a very close, they believe you?
I have not found any versus two good and cheap these cameras.
:EDIT AGAIN:
Just got back from a second run. Everything seemed okay for the most part. The camera seemed to record most if not all of the journey, but there are eight folders inside the DCIM folder.
One folder has locked files from before my first edit here, the other after. A third folder has one file i zoomed into a plate on to see if it would keep the zoom in the video (it does) although i know i zoomed more then one video. One folder has one clip that is about 6 seconds from when i accidentally hit the record button when i meant to hit the mode/lock button.
The way all the folders are named looks kind of odd. the last few numbers are the date, but i can't figure out the first few.
I bought this unit from estore009 and I'm not sure if I have a defective unit or I'm missing something. If I turn on motion detector, the default 3-min loop recording will always cut off around 5-15secs. I have to turn off the motion sensor for the recording to function properly. Another problem, the G-sensor does not work. I tried turning on the setting high and it will not record upon any shock vibration. I tested with another unit (I purchased two) and it seems to work flawlessly. Does this sound like a defective unit or am I missing something?
The camera needs to be running yes. I have not tried motion detection on my G1W yet, but on the DVR-027 it is just about useless. By the time it sensed a car driving by and started recording the car would be half way gone out of the shot.Does the camera need to be on for motion sensor and g-sensor to work?
I'm not %100 sure, but i believe it is ether one or the other. You can ether record full time or use motion detection. Maybe pressing record forces the camera to record for the time it would when it senses motion, but i am not sure I have not tested and never use MD myselfI bought this unit from estore009 and I'm not sure if I have a defective unit or I'm missing something. If I turn on motion detector, the default 3-min loop recording will always cut off around 5-15secs. I have to turn off the motion sensor for the recording to function properly.
As far as i know, i played around with them:
for motion detection camera hast to be ON, and motion detection has to be enabled, when it detects something in its viewing angle changing, it starts recording and stops after some time, waiting again for changes
in my opinion for fast moving objects as vehicles, bycycles and fast moving persons, too unreliable... in the recording you can see it starts way too late recording... the object is then only partly in the video or already gone
shock detection works another way, camera has to be ON and RECORDING, depending on the choosen shock sensivity setting it reacts to stronger or weaker vibration of camera, if the sensor detects a shock the camera protects the current recorded video from later being overwritten....thats all, thats supposed to be something like crash detection (you can manually protect video any time by pressing mode button while recording), it works indeed...on setting high protection was activated already when i just moved the cam slightly in the mount or pressed button on it
i didnt test though how reliable the file protection works from files being overwritten....since i use 32gb and 64gb and 16gb flashcards and it takes too long to wait out full recording cycle...too much hassle for now...too lazy : D
