D
Deleted member 24437
Guest
Say,@Gitup,does the Git 2's case accomidate the Git 3 camera?
No, the git 3 will be larger than the 1 and 2.Say,@Gitup,does the Git 2's case accomidate the Git 3 camera?
Roger that! I saw a post from Gitup showing the Git 3 2"(?) lcd with what appeared as a picture-in-picture of the bike-helmeted userThe reason is to fit a larger imaging sensor so it can work better in lower light levels and higher resolutions, and to hold a larger battery for longer recording time. Sounds like it's worth a small increase in size to me!
The main Git3 sensor diagonal (not model) is same with Git2 cam. Git3 body is thicker due to increased battery capacity and the touch screen. In theory Git1/2 waterproof case will fit with modified back cover.The reason is to fit a larger imaging sensor so it can work better in lower light levels and higher resolutions, and to hold a larger battery for longer recording time. Sounds like it's worth a small increase in size to me!
Not sure the lens would fit, and there is an issue with the buttons that means the Git3 will have a new case, not just a new back, but there is a plan for the Git2 with 4.1mm lens to fit in the Git3 case making use of the extra space for the lens, wont be able to use all the Git2 buttons though!The main Git3 sensor diagonal (not model) is same with Git2 cam. Git3 body is thicker due to increased battery capacity and the touch screen. In theory Git1/2 waterproof case will fit with modified back cover.
The button layout will not have any changes as far as I know.Not sure the lens would fit, and there is an issue with the buttons that means the Git3 will have a new case, not just a new back, but there is a plan for the Git2 with 4.1mm lens to fit in the Git3 case making use of the extra space for the lens, wont be able to use all the Git2 buttons though!
Then it has 2 lenses... that could be an interesting shape for the waterproof case, especially if you can change the direction of the 2nd lens!it's 2 channel
N | Using an external mike while in waterproof case | Git2 | 8 | |
O | Making Git2 Remote Waterproof? | Git2 | 7 | |
D | FOGGY LENS & CONDENSATION RING INSIDE WATERPROOF CASE | Git2 | 16 | |
Sena GP10 / waterproof housing work with Git2? | Git2 | 2 | ||
J | Where to buy Git2? + remote waterproof? | Git2 | 10 |
