Rhody401
- Jul 29, 2016
Warning: That appears to be for some other brand, and also appears to be passing along the full 12 volts, instead of having a transformer to bring it down to 5v. If you put 12v into it, it will likely burn out instantly.
There are several kits also out there to tie in direct, complete with transformer. (freeing up the original cable) See earlier in this thread.
One option is to keep what came with the kit, and just install a hidden power port port under the dash. Perhaps something like this: https://www.amazon.com/gp/B00G8WLW2YI am doing something similar to use the transformer that came with it, and can easily move the whole thing to another car in the future. (without cutting the wires on the original)
Another option is to install a "y" splitter in your power port, which turns it in to two power ports. Then you can plug in the dash cam and one other device, like a phone charger.
