Deleted member 46308
- Feb 19, 2018
Any help would be greatly appreciated. I have searched for, and was unsuccessful in finding an answer. I ran the 12v plug wire that came with my dash cam into the rear door of my Rav4. I then wired a female power outlet in the cargo area behind the interior panel and plugged the power end of my USB cable into this outlet to give me power for my DashCam.
Everything works fine with my camera powering properly, and my DashCam working just fine. Is there a way I can run a new wire from the fuse box, using an Add-A-Circuit for a dedicated power wire thus not using the female plug that I have wired. Which, by the way is drawing its power from an auxiliary plug that was in the cargo area already. This is the point where I am now stuck in my mind. Can I still use the power cable that I have already ran inside of all that door trim in back of my car, or am I going to have to run a new wire? Can I simply cut that plug off and attach to the leads of a 12v - 5v converter with my USB cable?
I realize that most of this is non-sensical to folks who know what they are doing, but I really cannot wrap my mind around what I should do next. I am wanting to make this change because everything works now off the ACC on my ignition, and I want it to start instead when the vehicle starts. Thanks in advance for any help that anyone might be able to provide me.
