Nosy Gorilla
- Jan 10, 2019
- Netherlands
I made an account just for this to give a more detailed explanation on how to update your firmware to English (from Chinese). All credits go to Rekysam as he was the original poster of this information. I merely give more explanation.
1. Set up the camera if this is not done yet, this is basically done by just passing the basic settings by pressing the far most right button
2. You format your sd card to exFAT.
3. Insert the sdcard in the camera, let the camera format it by pressing the right button when it asks to format it.
4. Now extract the folder called "update" out of the rar folder that Rekysam provided. Put this folder in the root of the sd card.
5. Now its time to update. Be sure to confirm that the camera is turned off at this point. This can be done by holding the big button on the below.
6. After the camera is off. Insert the sd card. The camera should remain off.
7. Now hold the most right button. While holding the last-mentioned button, press on the big button below and hold it as well.
8. Release both buttons once you that the update is being installed. If a red cross appears, the update has failed and it is most likely that the update folder in the sd card has been deleted. Repeat again from step 4.
If it updated successfully, you can restart the camera and the text will appear in English.
