Heat Issue
BKDilse
I've had my 1st heat issue with the 0805 after owning it for a few weeks...
Yesteraday the external temperature was around 24 deg celcius, and I can imagine the internal car temperature was probably higher. The cam only recorded for about 10 mins, and the frozed further recording. I could see loads of logs on the root of the SC card.
At the end of the journey, the cam did not shutdown as normal, so I had to do the 15 second button press to power it off.
I know cams don't like being left attached to the windscreen in hot weather, but I cannot be asked to remove it each time I leave my car parked.
My old 0801 never suffered from this (as far as I know).
I have another unit in the other car, which appeared to be working yesterday, so I've swapped it to test today.
Has anyone else had this issue?
thancam
Retailer
Hà Nội
Viet Nam
too many
try another memory card.
B
BKDilse
I have 2 of these cams, so here is what I did today:
Cam 1 (2-3 weeks old) - Changed the memory card to an older Samsung Class 6, 16GB, and tested it, and it failed. Shorter Journey.
Cam 2 (1 week old) - Put the Samsung Evo+ 64GB from Cam 1 in, and tested it, and it worked fine. Same 1 hour Journey.
Today was hotter than yesterday in the UK, and the Card does not appear to be the issue, as Cam 1 is still failing, but Cam 2 is working with the same card.
I'll be sending Cam 1 back for a refund, as soon as Cam 3 arrives.
These are great Cams, as long as there are no issues.
patecobrazil
Brazil
I have a 0801 on the rear glass and a 0805 on the windshield in my focus. I live in Brazil, and in the heat of here, my 0801 continues to work and the 0805 hangs very easily when the internal temperature reaches 35 ° C under the sun, no matter what memory card I use (sansung class 6). Sorry of my bad english
Enviado de meu XT1069 usando Tapatalk
B
BKDilse
I have the same as you, 0801 never has an issue. I'll keep testing the 2nd 0805 i have, which has not crashed yet.
