I just bought the new A119S version 2 and I don't like it one BIT that when you set GPS off in the menu,it's NOT really off.. WTH?? What purpose does that setting really serve then? I for one would like to see it actually turn off all GPS when you select it! I also do like the Electrical plug coming straight down rather then plugging it in on the side of the Camera. I take my Camera out of the Car every day so that was the ONLY reason I installed a GPS mount. If i unplug the Camera every single day,the connection won't last long at all. I need to have that Permanent mount with Electrical connection on it just like the GPS Mount but without GPS enabled. Would it possible to have the same mount configuration with just a Pass Through for voltage and NO Gps? Is there a way to disable this GPS mount in some way so it still provides Power but NO gps?? None of the other mounts available now give me a good option for Permanently mounting and hard wiring the mount so i can just Grab my camera and go without unplugging it every time. Could a new Firmware fix this since the option to turn OFF GPS already is listed in the menu,it's just NOT TRUE at this time.. not happy at all about this..
