I have tested the camera and am afraid it has a flaw which is responsible for my lost accident video.
I didn't format the sd card because I want it to test would the locked video files appear in the event folder now when it has correct time and date.
And everything is ok now, there is two lock video with the correct time and date. One I lock manually, the other is lock by triggering G sensor.
![47391 47391](https://dashcamtalk.com/forum/data/attachments/47/47192-d48525a924e0e11c97fa514684abd315.jpg?hash=1IUlqSTg4R)
So the final conclusion is:
Lock files in the EVENT folder can't be overwritten with files that are older than those in the event folder only with newer files. The lock video file will disappear in the DCIM folder and will not appear in the EVENT, it will be lost.
Here is an example in my case: I didn't drive the car for a few days, the camera lost to date and time, and set the default date to the year 2015, from that point normal video files will appear in DCIM folder regularly only with the wrong date. But unfortunately, there is no single new lock file in the EVENT folder. Lock files will keep disappearing in DCIM folder and it will be lost.
Even if you got an accident, with your camera set to wrong (default) date and you pull out power from the camera a few seconds after, G sensor already lock the file and it will be missing from DCIM folder and it be lost, because lock file with the year 2015 can't overwrite single newer lock file in event folder.
So keep your watch regularly on the camera date and time because you will lose an acident video file as it happens to me because of the wrong date and time.
I was very pleased with the camera for almost 9 months, with no problem and the first time when I really needed the camera and got an accident the camera fail to save video.
