Thanks. So to my understanding, even if you enable Parking Mode you have to enable motion detection aswell, otherwise it wont record in Parking mode? And even if you enable motion detection on top of parking mode, the camera could still not record some footage if no motion is detected.
Is there no way to force the camera to record continuously while in park?
Parking Mode uses motion detection and G-sensor as sensors to determine what record mode (Standby, Time-lapse, or Normal) to use at any given moment. In fact, the Motion Detection and Time-Lapse Recording menu settings can not be enabled while Parking Mode is enabled. Parking Mode operates autonomously while driving or parked, i.e., without need for operator intervention, a big pro. It has its cons too. Some like it and some don't.
You can't force Parking Mode to initiate the Standby/Time-lapse recording sub-modes in a practical manner during everyday operation. In a test scenario say at home, you can do it by covering the lens on the A119 for 90 seconds or so, but for me this didn't work for the A119S. For the A119S, I just had to create a static scene with some features and contrast (even if dimly lit) for the FOV and keep the camera still for 90 seconds or so.
You can force continuous Normal Recording by setting Parking Mode, Time-Lapse, and Motion Detection menu settings to OFF (it is the normal way of recording when Parking Mode is not used). All you need to do is keep the camera powered continuously, not necessarily a simple task in a car.
With Parking Mode set to OFF, you can force continuous Time-Lapse Recording by setting the Time-lapse Recording menu selection to something other than OFF. But this requires you to have to reset the Time-Lapse menu setting every time you want to turn it ON or OFF, for example to switch to Normal recording when driving. Again, you need to keep the camera powered if the ignition is OFF.
With Parking Mode set to OFF, the Time-Lapse Recording and Motion Detection menu settings can be enabled simultaneously. In this case, the camera records Time-lapse whenever motion in the FOV triggers the camera to record. No motion sensed in the FOV for 60 seconds stops recording. {Edit: Time-lapse recording will resume when motion is again detected in the camera FOV.}
