I checked the bootsound.raw file now. Import it to audacity with a frequency of 16khz. You will hear a normal turn-on sound, and if you import RAW with a frequency of 8 kHz, the sound will be slow, abnormal. Check it yourself.
Hi,
I have 70mai 1S (I think is the same 300M) and I want to turn off the sound as you describe here. Unfortunately the connection by telnet doesn´t work.
It wrotes me:
Failed to connect 192.168.0.1: Software caused connection abort
Is there some other IP or port which should I use for my cam?
Hi,
It wrotes me:
Thank you.
I cannot connect to my 70mai S500s with the most recent firmware. I use mobiletelnet , 192.168.0.1, 23, but it says connection refused. I hate the startup sound so much it is loud and irritating
Quick update: it is fairly easy to disable all sounds without damaging anything 🙂 All you need to do is to disassembly the device (6 screws in total) and unplug the speaker's connector. Not a big deal and it can be easily reverted to the original state.
Hi, of course you can!
You can use telnet by copying the folder with the voiceover to the memory card. For example, you have a voiceover in the root of the memory card in the "mysound" folder. In this folder you have sounds in AAC format.
OK...
Run the command and the voiceover from the "mysound" folder will be copied to the folder with your language, for example for English:
Below I post the original voiceover from firmware 1.0.14. See the name of the folder with your language and the AAC file format. It is important. The AAC file format should be as in the original:
Launch telnet, connect to the address: 192.168.0.1
After connecting, write: root
Next command: kill 214
Then:
Code:
tcpsvd -vE 0.0.0.0 21 ftpd -w / >/dev/null 2>&1 &
With this action, you have opened FTP access to the root of the file system! Great!
Connect with any FTP client, with the following parameters:
Address: 192.168.0.1
Username: root
We leave the password empty
And replace the voice acting through your smartphone or laptop.
The memory card is available at: \mnt\sdcard
Voice acting: \mnt\app\res\voice\
Sound on: \mnt\app\res\voice\public\bootsound.raw
Sound off: \mnt\app\res\voice\public\shutdown.aac
You can just delete or rename some sounds if you don't want to hear them.
After restarting the DVR, FTP access will be by default only to the memory card.
Hello lisabon_Q3,
I try your guide to access with ftp.
But with my M500 it doesn't work.
The kill 214 have no result -> no process found.
I can open with ftp, but I can't list the directory.
Do you have I idea what I make wrong?
Hello lisabon_Q3,
First you need to look at the list of processes with the command "ps" and end with the kill command with the process number with the name "inetd". Process number 214 is for A500s, you may have another one.
Hello, I’m bumping up a thread as seems like they blocked telnet with newest update.
Seems like only ports 80 and 554 are opened, telnet 23 is closed.
This power up sound is driving me mad again…
I just installed a 70mai A500s Pro Plus+ in my car and updated the firmware to version 1.8.57ww, and Telnet isn't working. Is there any way to change the ADAS alert sound? The sound is very annoying. I'd like to change it to a beep, but Telnet doesn't work with the method you described.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
