rcg530
- Jan 23, 2021
- California
- 70mai, BlackVue, Thinkware, Vantrue, Vueroid, VIOFO
LPID is not one of the "Normal Parking Mode" options only Auto Event Detection, Time-Lapse, and Low Bitrate are in that grouping of parking modes.Thanks again. I understand now theres no setting called "normal parking mode" that was just a term you used to describe settings like "Auto Event Detection", "LPID" etc..
To get buffered parking mode recordings you have to use one of the three "Normal Parking Mode" options. 12.2V is probably as low as I would go with a low voltage cut-off feature setting if that's the cut-off setting that will turn off the dash camera. There's always a little bit of wiggle room +/- 0.1V or even 0.2V when it comes to the accuracy of the voltage cut-off circuitry being used in any dash camera.So the short answer is the way my current settings are set are probably the best in terms of the longest I can get in a buffering parking recording and without getting a flat battery as battery cut off is set at 12.2v.
Yes?
