How would I go about hardwired a dash cam safely?
winter4w
G1WH
So I got a G1WH and am wondering how would I go about hardwiring it? I was going to get this kit (https://www.amazon.com/gp/B071K9J2ZP) off Amazon. My question is, would I need to get an add a fuse for this or would it be ok to wrap the cable around the fuse leg? Also, does it matter what amp fuse I would need to put it in since there is an "In-line fuse for added protection"?
I am guessing if it is a 15amp fuse in there it would be dangerous to put it with a 10amp?
winter4w
winter4w
G1WH
get a fuse tap, don't wrap wires around a fuse leg, too easy to short something without noticing it
Ok and will it matter what amp fuse I put it in or no? And also what amp fuse would I get for the fuse tap?
jokiin
Too many ¯\_(ツ)_/¯
that power supply has its own low amperage fuse inline right at the power connector anyway so what size fuse you put in the tap won't matter a great deal in the scheme of things, 5A is plenty
winter4w
winter4w
G1WH
Would 2A do I was reading around and people seem to recommend 2A? Just trying to avoid a fire lol :p
I have plans to hardwire a G1WH and if that goes well to hardwire the A199S in the other car.
jokiin
Too many ¯\_(ツ)_/¯
2A is fine, the power supply likely has a 2A fuse in it already, the fuse being so close to the tap would make it a non issue anyway
jokiin
Too many ¯\_(ツ)_/¯
winter4w
winter4w
G1WH
convenient but in my experience that's a problem model, voltage output is not stable, we've had a few customers kill our cameras using those, more expensive doesn't always equal better
So I'm guessing the Amazon one I linked is stable or do you know of any stable hardwire kits?
Finch204
I was using Inviscord to plug my dash cam into the auto-dimming mirror in my Mazda. Clean and easy install.
abarth
SF bay area, California
SGZC12RC░░ mini0805░░ viofoA119░░B1W
jeez123
Denmark
Blackvue DR650S-2CH
I can personally vouch for the multi safer BDP since it's been running reliably in my vehicle for 2+ years now. a lot of folks here like the newer, more feature rich vico power plus, too. i'll probably get that if my multisafer ever quits.
Me 2 am running the MotoPark Power Safer (FineVu Multi Safer - same product, new brand), for almost 4 months now, no troubles what so ever. Highly satisfied.
