Do you leave WiFi turned on normally? I noticed more compress artifacts than my A119. And in this thread after some troubleshooting found the bitrate nearly halved with WiFi turned on.
A129 Video artifacts
https://dashcamtalk.com/forum/threads/a129-video-artifacts.35105/
Here's the bitrate on file of the raw video I posted. I have it set on high.What’s the bitrate you’re getting on the files? Also what bitrate do you have the camera set to?
Is there a way to improve or fix it?
Everything can be fixed ... BUTIs there a way to improve or fix it?
The way is, your DDA is on a guarantee, you better contact the supplier.
Yea, the quality of my videos seem to be worse than the other A129 videos I see posted.Those videos in the OP by Andy look pretty bad to me. Day, front, rear and night all appear off ... I wouldn't be happy.
I turned off wifi, but still the quality doesn't seem on par with other A129 videos I seen online.
https://drive.google.com/open?id=1h9ZVdU_UfRfQZzEctBta6Wav5PtcwBfv
I used some black sheets and that has significantly reduced the reflection, I plan on getting a dash mat for a more permanent solution to the glare.In this video specifically, I think your cam is severely impacted by the reflection of your dash showing up on your cam. Can you up the cam angle a notch and test it and see if the same results happen? Or can you find a day that is less sunny and see if the videos are still that bad? (also definitely leave the WiFi off while recording, because there is a bug that affects the bit-rate)
Good idea, I will give this a try. I doesn't need to mount to record.To eliminate windshield glare as a potential problem remove the camera from the car and take stationary video in the open.
If the video is beautiful you need a cpl desperately. If the video is horrible without glass in the way the camera must be out of focus or otherwise defective.
As long as the mount is not required for power this should work.
