peterhr said:
If the rear camera image is inverted
- unstick the camera from the window, rotate it 180 degrees (so the wire that was on the right is now on the left)
- stick the camera back on
- rotate the lens which is now looking forwards - so it now looks out the rear window
... Fixed
I had a 720p delivered a couple of days ago and so far I'm quite impressed with it. Not sure how the above would work and I would like to swap the image left to right, so it matches my interior mirror view. Surely doing the above would swap it left to right, but would also swap it top for bottom - the image would be upside down?
I have it set to high on the G-sensor and despite tapping the camera, it has so far recorded nothing.
The front camera is almost useless in the dark, the rear one is much better, but much also seems to depend on the video player use.
I ordered a 32GB C10 card from another seller and that proved to be a fake, so I made do with a 16GB C4 I had. That has been fine, I only spotted one slight glitch in 1.5 hours of recording, in the middle of a ten minute run. The RT off setting is recording in blocks of 10 minutes, with barely any loss (or maybe even some overlap) between files.
Regarding the mentioned interference on 2M and FM radio - has anyone thought to try adding some ferrite rings on the rear camera and Power leads?
I'm wondering with the mentioned of GPS fed into it, I could feed GPS sentences into it, from a normal receiver?
Mine has an Exposure setting in the menu, has anyone tried adjusting that setting, to improve the night performance of the front camera?
System Info shows Firmware - F20_20130613 (13th June 2013?)
