up date on upside/down: when i go to default the image goes right side up ,but if i change the 1080p to 720p then the next time i turn off the unit and restart its us/d again. it looks like i have to leave it set to 1080p... this ok but wont this make my files larger?? so far i think i can change other settings in the menu's with out the us/d reoccurring, maybe!!![]()
story of my life![]()
just got my hd 1080 dvr and the screen image for the forward facing camera is upside/down. when i turn the unit 180 degrees it is still upside/down . any ideas?? i reset the unit to no avail. i found out how to change to English by reading this forum so hopping to get more info here.
I dont know how to update the cam by placing the image file on the card.
I succeffully updated mine to F20_20130122 with the software LiveSuit.
I had to hold arrow up button and pressing power button. The camera starts in a update mode, and wants some drivers that are in the driver folder of lifesuit.
After succefully installing these drivers you can flash the firmware with lifesuite.
After Flashing is done the cam reboots.
Done.
Its a little bit dificult because the software is not easy to handle.
If You want to retry it your way, try to name the imagefile epos.img
I would think so, have you tried it out?I can see I triangular hazard sign on one of the buttons. Is it an sos button like the vicovation has?
Well, I bought It from ebay and it arrived today. It does indeed work as an sos button but only records like 10 seconds before and after you press it. Also it was advertised as recording in .avi but actually records in .mov.I would think so, have you tried it out?
