TNT
- May 10, 2015
- Slovakia
- SG9663DC
Here is my install of the rear camera. It was not as bad as I figured it would be. The front camera was simple and there are many photos of the front cam being installed and its really not different from any other vehicle.
Remove 4 screws from bottom of hatch
Remove pull strap cap and bolt/screw
Pull bottom and 2 side panels off
Remove 2 screws from top panel
Pull top panel off
Pull out rubber grommet from side with wires. Do not do the side that has the hose for the washer fluid
Use 2 zip ties. Feed first one through from bottom. Use second zip tie to lock the first one in place.
Some sites say use a lubricant to help the wire through, but I dont like the idea of getting anything liquid into the plug so I did it dry slowly working it through.
The rest is easy. Pull back any of the rubber seals to tuck the wire behind.
Photos of finished mountings:
If anyone wants any other photos, I can take them. It was dark by the time I was complete so I have no daytime photos yet to see the cams from outside better.
Pull top panel off
