- Feb 6, 2016
- New England
- United States
- Viofo, GitUp
They are the same camera. A119 is $90, A119S is $110.
Make sure the charger puts out at least 1A. Other chargers should work fine, they just need to put out enough power.Are these dash cams like require a specific charger? When I tired 2 diffferent car chargers the have problem staying on but when I try the viofo car charger it works. How come other car chargers don’t work.
I have a charger that puts out 1 amp and 2.1 amp. Other stuff chargers fine. I tried connecting just the viofo and even still it keeps turning on and off. I know it can’t be my charger because I tried 2 different chargers and 2 different usb built in charger.Make sure the charger puts out at least 1A. Other chargers should work fine, they just need to put out enough power.
12-volt cigarette lighter receptacle and plug, size A
12-volt cigarette lighter receptacle and plug, size B
- Receptacle inside diameter: 20.93–21.01 mm (median 20.97 mm)
- Plug body diameter: 20.73–20.88 mm (median 20.805 mm)
- Most often used in American automobiles
- Receptacle inside diameter: 21.41–21.51 mm (median 21.455 mm)
- Plug body diameter: 21.13–21.33 mm (median 21.18 mm)
inadequate
Even if writing on them or in the manual suggest otherwise, its like the 4K thing, people put buzz words on the product to make it sell better, which it probably do as we people are also bad shoppers.
Like I said the original usb mini works but if I try any other usb mini I get distorted color and for some reason the dash cam turns on and off.
5 | Viofo a229 pro rear dash camera to LCD screen | Dash Cam Discussion | 1 | |
L | Dashcsm | Dash Cam Discussion | 0 | |
Dash Cam Compatability | Dash Cam Discussion | 0 | ||
T | Dash Cam wiring for CB1300 | Dash Cam Discussion | 0 | |
G | Crosstour dashcam app | Dash Cam Discussion | 0 |
