<5>Linux version 2.6.18_pro500-davinci_IPNC_DM368_2.0.0-g0f88b6df-dirty (sychoi@server) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Mon Nov 19 15:19:51 KST 2012
<4>CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
<4>Machine: DaVinci DM368 IPNC
<4>Memory policy: ECC disabled, Data cache writeback
<7>On node 0 totalpages: 12800
<7> DMA zone: 12800 pages, LIFO batch:3
<6>DaVinci DM0365 variant 0x8
<6>PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000
<6>PLL0: vencrate_sd: 75555555, ddrrate: 340000000 mmcsdrate: 48571428
<6>PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000
<4>CPU0: D VIVT write-back cache
<4>CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
<4>CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
<4>Built 1 zonelists. Total pages: 12800
<5>Kernel command line: mem=50M console=ttyS1,115200n8 root=/dev/ram0 rw initrd=0x82000000,13M ip=dhcp eth=$(ethaddr)
<4>PID hash table entries: 256 (order: 8, 1024 bytes)
<6>Clock event device timer0_0 configured with caps set: 07
<4>Console: colour dummy device 80x30
<4>Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
<4>Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
<6>Memory: 50MB = 50MB total
<5>Memory: 33408KB available (3036K code, 633K data, 172K init)
<7>Calibrating delay loop... 215.44 BogoMIPS (lpj=1077248)
<6>Security Framework v1.0.0 initialized
<6>Capability LSM initialized
<4>Mount-cache hash table entries: 512
<6>CPU: Testing write buffer coherency: ok
<6>checking if image is initramfs...it isn't (bad gzip magic numbers); looks like an initrd
<6>Freeing initrd memory: 13312K
<6>NET: Registered protocol family 16
<6>DaVinci: 104 gpio irqs
<4>MUX: initialized GPIO20
<4>MUX: initialized I2C_SCL
<3>Invalid PINMUX index: 94, max 94
<6>Generic PHY: Registered new driver
<5>ch0 default output "COMPOSITE", mode "NTSC"
<7><vpbe_encoder_setoutput>
<7>Setting output to Composite
<7>Start of vpbe_encoder_setmode..
<7></vpbe_encoder_setmode>
<7></vpbe_encoder_setoutput>
<7>VPBE Encoder initialized
<7><vpbe_encoder_enumoutput>
<7></vpbe_encoder_enumoutput>
<7><vpbe_encoder_getoutput>
<7></vpbe_encoder_getoutput>
<7><vpbe_encoder_getmode>
<7><vpbe_encoder_getmode/>
<5>VPBE Encoder Initialized
<6>NET: Registered protocol family 2
<4>IP route cache hash table entries: 512 (order: -1, 2048 bytes)
<4>TCP established hash table entries: 2048 (order: 1, 8192 bytes)
<4>TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
<6>TCP: Hash tables configured (established 2048 bind 1024)
<6>TCP reno registered
<5>VFS: Disk quotas dquot_6.5.1
<4>Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<6>squashfs: version 3.1 (2006/08/19) Phillip Lougher
<6>JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
<4>yaffs Nov 19 2012 15:20:57 Installing.
<6>SGI XFS with no debug enabled
<6>Initializing Cryptographic API
<6>io scheduler noop registered
<6>io scheduler anticipatory registered (default)
<6>LTT : ltt-facilities init
<6>LTT : ltt-facility-core init in kernel
<6>DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
<6>serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A
<6>serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A
<4>RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
<6>dm9000 Ethernet Driver
<6>Linux video capture interface: v2.00
<7><davinci_display_init>
<5>Trying to register davinci display video device.
<5>layer=c2c76000,layer->video_dev=c2c76160
<5>layer=c0ccde00,layer->video_dev=c0ccdf60
<5>davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
<7></davinci_init>
<6>i2c /dev entries driver
<6>nand_davinci nand_davinci.0: Using 4-bit hardware ECC
<6>NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
<7>Bad block table found at page 65472, version 0x01
<7>Bad block table found at page 65408, version 0x01
<7>nand_read_bbt: Bad block at 0x01160000
<7>nand_read_bbt: Bad block at 0x01540000
<7>nand_read_bbt: Bad block at 0x019c0000
<7>nand_read_bbt: Bad block at 0x03ee0000
<5>Creating 5 MTD partitions on "nand_davinci.0":
<5>0x00000000-0x00660000 : "bootloader"
<5>0x00660000-0x00680000 : "params"
<5>0x00680000-0x00880000 : "kernel"
<5>0x00880000-0x00e80000 : "cramfs"
<5>0x00e80000-0x08000000 : "filesystem"
<6>nand_davinci nand_davinci.0: hardware revision: 2.3
<6>davinci-mmc davinci-mmc.0: Supporting 4-bit mode
<6>davinci-mmc davinci-mmc.0: Using DMA mode
<6>Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).
<6>ASoC version 0.13.1
<6>CQ0093 Voice Codec 0.1
<6>asoc: cq93vc <-> davinci-vcif mapping ok
<6>ALSA device list:
<6> #0: On-chip voice codec (cq93vc)
<6>IPv4 over IPv4 tunneling driver
<6>TCP bic registered
<6>NET: Registered protocol family 17
<6>Time: timer0_1 clocksource has been installed.
<6>Clock event device timer0_0 configured with caps set: 08
<6>Switched to high resolution mode on CPU 0
<6>mmcblk0: mmc0:b368 7822336KiB
<6> mmcblk0: p1
<3>IP-Config: No network devices available.
<5>RAMDISK: cramfs filesystem found at block 0
<5>RAMDISK: Loading 5192KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|done.
<4>VFS: Mounted root (cramfs filesystem) readonly.
<6>Freeing init memory: 172K
<3>FAT: bogus number of reserved sectors
<6>VFS: Can't find a valid FAT filesystem on dev mmcblk0.
<6>yaffs: dev is 32505860 name is "mtdblock4"
<6>yaffs: passed flags ""
<4>yaffs: Attempting MTD mount on 31.4, "mtdblock4"
<4>block 24 is bad
<4>block 55 is bad
<4>block 91 is bad
<4>block 388 is bad
<4>block 905 is bad
<4>block 906 is bad
<4>block 907 is bad
<4>block 908 is bad
<4>yaffs_read_super: isCheckpointed 0
<6>CSL: Module install successful, device major num = 254
<6>CSL: Module version 0.10.00, built on Nov 19 2012 15:22:34
<6>I2C: Module install successful, device major num = 253
<6>DMA: Module install successful, device major num = 252
<6>DRV: Module install successful
<6>DRV: Module built on Nov 19 2012 15:22:35
<6>DRV: EDMACC.QUEPRI = 00000777
<6>DRV: SYSTEM.MSTPRI0 = 00550011
<6>DRV: SYSTEM.MSTPRI1 = 00000444
<6>DRV: ISP.BCR = 00000002
<6>DRV: SYSTEM.MISC = 00000319
<6>CMEMK module: built on Mar 21 2012 at 18:02:40
<6> Reference Linux version 2.6.18
<6> File /home/sychoi/FHDBB/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<6>allocated heap buffer 0xc4000000 of size 0x4400000
<4>CMEM Range Overlaps Kernel Physical - allowing overlap
<4>CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83200000)
<6>cmemk initialized
<6>EDMAK module: built on Mar 21 2012 at 18:02:41
<6> File /home/sychoi/FHDBB/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
<6>IRQK module: built on Mar 21 2012 at 18:02:42
<6> File /home/sychoi/FHDBB/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
<6>irqk initialized
<6>io scheduler deadline registered
<6>io scheduler cfq registered
<6> sbulla: unknown partition table
<7>VPBE Encoder de-initialized
<5>DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:
<4>layer.pix_fmt.bytesperline = 736,
<4> layer.pix_fmt.width = 720,
<4> layer.pix_fmt.height = 480,
<4> layer.pix_fmt.sizeimage =529920
<5>DavinciDisplay DavinciDisplay.1: pixfmt->width = 720,
<4> layer->layer_info.config.line_length= 736
<3>DavinciDisplay DavinciDisplay.1: Invalid crop values
<3>DavinciDisplay DavinciDisplay.1: Error in S_CROP params
