www.pudn.com > ipnc_app.rar > Appro_avi_save.c, change:2008-08-25,size:28579b
* Libavformat API example: Output a media file in any supported
* libavformat format. The default codecs are used.
* Copyright (c) 2003 Fabrice Bellard
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <malloc.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <unistd.h>
#include <time.h>
#include <ApproDrvMsg.h>
#include <Appro_interface.h>
#include <cmem.h>
#include <Msg_Def.h>
#include <sys/dir.h>
#include <sys/statfs.h>
#include <signal.h>
#ifndef M_PI
#define M_PI 3.14159265358979323846
#endif
#include "avformat.h"
#include "swscale.h"
#undef exit
#define ERR(fmt, args...) fprintf(stdout, "%s: error: " fmt, __FILE__, ##args)
/* 5 seconds stream duration */
int STREAM_FRAME_RATE = 30;
int STREAM_FRAME_ID = 1;
#define PRE_BUFFER (30)
#define STREAM_PIX_FMT PIX_FMT_YUV420P /* default pix_fmt */
char MMC_PATH[] = "/mnt/mmc";
char TMP_PATH[] = "/tmp";
char *pCurr_path = TMP_PATH;
/* audio output */
float t, tincr, tincr2;
int16_t *samples;
uint8_t *audio_outbuf;
int audio_outbuf_size;
int audio_input_frame_size;
int AbortSignal = 0;
double Pts_Addon_Duration = 0;
int Audio_Serial_Start = -1;
int Video_Serial_Start = 0;
static int mpeg4_field[7][2] =
{AV_OP_LOCK_MP4_VOL, AV_OP_LOCK_MP4_CIF_VOL},
{AV_OP_UNLOCK_MP4_VOL, AV_OP_UNLOCK_MP4_CIF_VOL},
{AV_OP_LOCK_MP4, AV_OP_LOCK_MP4_CIF},
{AV_OP_LOCK_MP4_IFRAME, AV_OP_LOCK_MP4_CIF_IFRAME},
{AV_OP_UNLOCK_MP4, AV_OP_UNLOCK_MP4_CIF},
{AV_OP_GET_MPEG4_SERIAL, AV_OP_GET_MPEG4_CIF_SERIAL},
{AV_OP_WAIT_NEW_MPEG4_SERIAL, AV_OP_WAIT_NEW_MPEG4_CIF_SERIAL}};
#define LOCK_MP4_VOL 0
#define UNLOCK_MP4_VOL 1
#define LOCK_MP4 2
#define LOCK_MP4_IFRAM 3
#define UNLOCK_MP4 4
#define GET_MPEG4_SERIAL 5
#define WAIT_NEW_MPEG4_SERIAL 6
int GetAudioInterface( unsigned long *pAddr , int *pSize, double *pTime, int IsClean);
int GetVideoInterface( unsigned long *pAddr , int *pSize, int *IsKey, double *ptime ,int IsClean);
void WaitVideoStart( void );
int GetVideoInfo( int typeID, AV_DATA *pInfo )
int vType = typeID;
//AV_DATA av_data;
if( GetAVData(mpeg4_field[GET_MPEG4_SERIAL][vType], -1, pInfo )!= RET_SUCCESS )
return -1;
}else{
//memcpy( pInfo, &av_data, sizeof(AV_DATA) );
return 0;
* 0 : read
* > 0 : write
double Controlbasetime( double SetVal )
static double basetime = 0;
if( SetVal == 0 )
return basetime;
else
if( basetime )
if( SetVal > basetime )
basetime = SetVal;
else
basetime = SetVal;
return basetime;
* add an audio output stream
static AVStream *add_audio_stream(AVFormatContext *oc, int codec_id)
AVCodecContext *c;
AVStream *st;
st = av_new_stream(oc, 1);
if (!st) {
fprintf(stderr, "Could not alloc stream\n");
exit(1);
c = st->codec;
c->codec_id = codec_id;
c->codec_type = CODEC_TYPE_AUDIO;
/* put sample parameters */
c->bit_rate = 64000;
c->sample_rate = 8000;
c->channels = 1;
return st;
static void open_audio(AVFormatContext *oc, AVStream *st)
AVCodecContext *c;
AVCodec *codec;
c = st->codec;
/* find the audio encoder */
codec = avcodec_find_encoder(c->codec_id);
if (!codec) {
fprintf(stderr, "codec not found\n");
exit(1);
/* open it */
if (avcodec_open(c, codec) < 0) {
fprintf(stderr, "could not open codec\n");
exit(1);
/* init signal generator */
t = 0;
tincr = 2 * M_PI * 110.0 / c->sample_rate;
/* increment frequency by 110 Hz per second */
tincr2 = 2 * M_PI * 110.0 / c->sample_rate / c->sample_rate;
audio_outbuf_size = 8000;
audio_outbuf = av_malloc(audio_outbuf_size);
/* ugly hack for PCM codecs (will be removed ASAP with new PCM
support to compute the input frame size in samples */
if (c->frame_size <= 1) {
audio_input_frame_size = audio_outbuf_size / c->channels;
switch(st->codec->codec_id) {
case CODEC_ID_PCM_S16LE:
case CODEC_ID_PCM_S16BE:
case CODEC_ID_PCM_U16LE:
case CODEC_ID_PCM_U16BE:
audio_input_frame_size >>= 1;
break;
default:
break;
} else {
audio_input_frame_size = c->frame_size;
samples = av_malloc(audio_input_frame_size * 2 * c->channels);
static int write_audio_frame(AVFormatContext *oc, AVStream *st)
AVCodecContext *c;
AVPacket pkt;
unsigned long ulAddr = 0;
int audio_size = 0;
static double audioLasttime = -1;
double audiotime = 0;
double audiotimediff = 0;
double InvCnt = 0;
av_init_packet(&pkt);
c = st->codec;
if( GetAudioInterface(&ulAddr,&audio_size,&audiotime,0) < 0)
return -1;
if( audioLasttime < 0 )
audioLasttime = audiotime;
Controlbasetime( audioLasttime );
pkt.size= audio_size;//avcodec_encode_audio(c, audio_outbuf, audio_outbuf_size, samples);
pkt.pts= av_rescale_q(c->coded_frame->pts, c->time_base, st->time_base);
pkt.flags |= PKT_FLAG_KEY;
pkt.stream_index= st->index;
pkt.data= (uint8_t *)ulAddr;//audio_outbuf;
audiotimediff = audiotime - Controlbasetime(0);
if( audiotimediff < 0 )
audiotimediff = 0;
InvCnt = audiotimediff/(double)1000.0 * (double)st->time_base.den / (double)st->time_base.num ;
st->pts.val = InvCnt;
/*fprintf( stderr, "\n\naudio num = %f\n", (double)st->time_base.num);
fprintf( stderr, "audio den = %f\n", (double)st->time_base.den);
fprintf(stderr, "audiotimediff = %f\n", (double)audiotimediff);
fprintf(stderr, "audio st->pts.val = %f\n", (double)st->pts.val);
/* write the compressed frame in the media file */
if (av_write_frame(oc, &pkt) != 0) {
fprintf(stderr, "Error while writing audio frame\n");
exit(1);
return 0;
static void close_audio(AVFormatContext *oc, AVStream *st)
avcodec_close(st->codec);
av_free(samples);
av_free(audio_outbuf);
/* video output */
AVFrame *picture, *tmp_picture;
uint8_t *video_outbuf;
int frame_count, video_outbuf_size;
/* add a video output stream */
static AVStream *add_video_stream(AVFormatContext *oc, int codec_id)
AVCodecContext *c;
AVStream *st;
AV_DATA av_Info;
if( GetVideoInfo( STREAM_FRAME_ID, &av_Info ) < 0 )
fprintf(stderr, "Could not GetVideoInfo() \n");
exit(1);
st = av_new_stream(oc, 0);
if (!st) {
exit(1);
c = st->codec;
c->codec_type = CODEC_TYPE_VIDEO;
c->bit_rate = 4000000/8;//av_Info.quality;
/* resolution must be a multiple of two */
c->width = av_Info.width;
c->height = av_Info.height;
/* time base: this is the fundamental unit of time (in seconds) in terms
of which frame timestamps are represented. for fixed-fps content,
timebase should be 1/framerate and timestamp increments should be
identically 1. */
c->time_base.den = STREAM_FRAME_RATE;
c->time_base.num = 1;
c->gop_size = 10; /* emit one intra frame every twelve frames at most */
c->pix_fmt = STREAM_PIX_FMT;
if (c->codec_id == CODEC_ID_MPEG2VIDEO) {
/* just for testing, we also add B frames */
c->max_b_frames = 2;
if (c->codec_id == CODEC_ID_MPEG1VIDEO){
/* Needed to avoid using macroblocks in which some coeffs overflow.
This does not happen with normal video, it just happens here as
the motion of the chroma plane does not match the luma plane. */
c->mb_decision=2;
// some formats want stream headers to be separate
if(!strcmp(oc->oformat->name, "mp4") || !strcmp(oc->oformat->name, "mov") || !strcmp(oc->oformat->name, "3gp"))
c->flags |= CODEC_FLAG_GLOBAL_HEADER;
return st;
static void open_video(AVFormatContext *oc, AVStream *st)
AVCodec *codec;
AVCodecContext *c;
c = st->codec;
/* find the video encoder */
if (!codec) {
exit(1);
/* open the codec */
exit(1);
video_outbuf = NULL;
picture = NULL;
tmp_picture = NULL;
#if 0
if (!(oc->oformat->flags & AVFMT_RAWPICTURE)) {
/* allocate output buffer */
/* XXX: API change will be done */
/* buffers passed into lav* can be allocated any way you prefer,
as long as they're aligned enough for the architecture, and
they're freed appropriately (such as using av_free for buffers
allocated with av_malloc) */
video_outbuf_size = 200000;
video_outbuf = av_malloc(video_outbuf_size);
/* allocate the encoded raw picture */
picture = alloc_picture(c->pix_fmt, c->width, c->height);
if (!picture) {
fprintf(stderr, "Could not allocate picture\n");
exit(1);
/* if the output format is not YUV420P, then a temporary YUV420P
picture is needed too. It is then converted to the required
output format */
tmp_picture = NULL;
if (c->pix_fmt != PIX_FMT_YUV420P) {
tmp_picture = alloc_picture(PIX_FMT_YUV420P, c->width, c->height);
if (!tmp_picture) {
fprintf(stderr, "Could not allocate temporary picture\n");
exit(1);
#endif
static int write_video_frame(AVFormatContext *oc, AVStream *st)
int out_size;
int IsKey = 0;
static double videoLasttime = -1;
double videotime = 0;
double videotimediff = 0;
double InvCnt = 0;
int ret;
AVCodecContext *c;
c = st->codec;
/* encode the image */
if( GetVideoInterface( &ulAddr,&out_size,&IsKey, &videotime ,0) < 0 )
return -1;
//fprintf( stderr,"video time = %f \n", videotime );
if( videoLasttime < 0 )
videoLasttime = videotime;
Controlbasetime( videoLasttime );
c->coded_frame->key_frame = IsKey;
if (out_size > 0) {
AVPacket pkt;
if(c->coded_frame->key_frame)
pkt.data= (uint8_t *)ulAddr;//video_outbuf;
pkt.size= out_size;
videotimediff = videotime - Controlbasetime(0);
if( videotimediff < 0 )
videotimediff = 0;
InvCnt = videotimediff/(double)1000.0 * (double)st->time_base.den / (double)st->time_base.num ;
/*fprintf( stderr, "\n\n videonum = %f\n", (double)st->time_base.num);
fprintf( stderr, " video den = %f\n", (double)st->time_base.den);
fprintf( stderr, " videotimediff = %f\n", videotimediff);
fprintf( stderr, " videopts.val = %f\n\n", (double)st->pts.val);
ret = av_write_frame(oc, &pkt);
} else {
ret = 0;
if (ret != 0) {
fprintf(stderr, "Error while writing video frame\n");
exit(1);
frame_count++;
return 0;
static void close_video(AVFormatContext *oc, AVStream *st)
if( picture )
av_free(picture->data[0]);
av_free(picture);
if (tmp_picture) {
av_free(tmp_picture->data[0]);
av_free(tmp_picture);
if( video_outbuf )
av_free(video_outbuf);
int vType = STREAM_FRAME_ID;
AV_DATA av_data;
while(1)
GetAVData(mpeg4_field[GET_MPEG4_SERIAL][vType], -1, &av_data );
if( av_data.flags != AV_FLAGS_MP4_I_FRAME )
usleep(3);
}else{
Video_Serial_Start = av_data.serial - PRE_BUFFER;
break;
char AVI_FirstFrame[80*1024];
int GetVideoInterface( unsigned long *pAddr , int *pSize, int *IsKey , double *ptime ,int IsClean)
AV_DATA vol_data;
static int SerialBook = -1;
static int SerialLock = -1;
static int IsFirst = 1;
int nOffset = 0;
int ret = 0;
AV_DATA av_data;
char mpeg4_header[] = {0x00, 0x00, 0x01, 0xb0, 0x01, 0x00, 0x00, 0x01, 0xb5, 0x09};
if( IsClean == 0 )
if( SerialBook < 0 )
memcpy( (AVI_FirstFrame+nOffset), mpeg4_header, sizeof(mpeg4_header));
nOffset += sizeof(mpeg4_header);
if(GetAVData(mpeg4_field[LOCK_MP4_VOL][vType], -1, &vol_data) != RET_SUCCESS)
ERR("Error on Get Vol data\n");
return -1;
memcpy( (AVI_FirstFrame+nOffset), vol_data.ptr, vol_data.size);
nOffset += vol_data.size;
/*do
} while (av_data.flags != AV_FLAGS_MP4_I_FRAME);
SerialBook = av_data.serial;
SerialBook = Video_Serial_Start;
while(1)
ret = GetAVData(mpeg4_field[LOCK_MP4][vType], SerialBook, &av_data );
if (ret == RET_SUCCESS)
if( IsFirst == 1 )
memcpy( (AVI_FirstFrame+nOffset), av_data.ptr, av_data.size);
nOffset += av_data.size;
*pAddr = (unsigned long)AVI_FirstFrame;
*pSize = nOffset;
Audio_Serial_Start = av_data.ref_serial[FMT_AUDIO];
//fprintf(stderr,"Video_Serial_Start = %d \n",Video_Serial_Start);
//fprintf(stderr,"Audio_Serial_Start = %d \n",Audio_Serial_Start);
IsFirst = 0;
}else{
*pAddr = (unsigned long)av_data.ptr;
*pSize = (int)av_data.size;
if( av_data.flags == AV_FLAGS_MP4_I_FRAME )
*IsKey = 1;
else
*IsKey = 0;
*ptime = av_data.timestamp;
if (SerialLock >= 0)
GetAVData(mpeg4_field[UNLOCK_MP4][vType], SerialLock, &av_data);
SerialLock = SerialBook;
SerialBook++;
return 0;
else if (ret == RET_NO_VALID_DATA) {
/* wait new frame */
//GetAVData(mpeg4_field[WAIT_NEW_MPEG4_SERIAL][vType], -1, &av_data );
//usleep(5);
return -1;
else {
WaitVideoStart();
else
SerialBook = -1;
SerialLock = -1;
IsFirst = 1;
return 0;
int SaveVideoFile( char *pFileName , int save_cnt)
FILE *pfd = NULL;
AV_DATA vol_data;
int error_code = 0;
int ret = 0;
AV_DATA av_data;
pfd = fopen(pFileName,"wb");
if( pfd == NULL )
ERR("open file error!!");
error_code = -1;
goto RECORD_QUIT;
if( fseek( pfd, 0, SEEK_SET ) < 0)
ERR("seek file error!!");
error_code = -1;
goto RECORD_QUIT;
if( fwrite( mpeg4_header , sizeof(char), sizeof(mpeg4_header), pfd ) <= 0 )
ERR("save file error!!");
error_code = -1;
goto RECORD_QUIT;
goto RECORD_QUIT;
if( fwrite( vol_data.ptr , sizeof(char), vol_data.size, pfd ) <= 0)
error_code = -1;
goto RECORD_QUIT;
GetAVData(mpeg4_field[UNLOCK_MP4_VOL][vType], -1, &vol_data);
do
while( save_cnt > 0)
if( fwrite( av_data.ptr,av_data.size,1, pfd ) <= 0)
error_code = -1;
goto RECORD_QUIT;
save_cnt--;
SerialBook++;
else {
RECORD_QUIT:
if( pfd )
fclose(pfd);
return error_code;
int error_code = 0;
int ret = 0;
AV_DATA av_data;
if( IsClean == 0 )
while(1)
if( Audio_Serial_Start < 0 )
do
GetAVData(AV_OP_GET_ULAW_SERIAL, -1, &av_data );
fprintf(stderr,"Audio_Serial_Start = %d \n",av_data.serial);
} while (av_data.serial < 0);
}else{
SerialBook = Audio_Serial_Start;
ret = GetAVData(AV_OP_LOCK_ULAW, SerialBook, &av_data );
//fprintf(stderr, "GetAudioInterface %d \n",SerialBook );
*pTime = av_data.timestamp;
GetAVData(AV_OP_UNLOCK_ULAW, SerialLock, &av_data);
SerialBook++;
return 0;
else {
if( SerialBook > av_data.serial )
//GetAVData(AV_OP_WAIT_NEW_ULAW_SERIAL, -1, &av_data );
//usleep(5);
return -1;
}else{
else
SerialBook = -1;
SerialLock = -1;
return error_code;
int SaveAudioFile( char *pFileName , int save_cnt)
FILE *pfd = NULL;
int error_code = 0;
int ret = 0;
AV_DATA av_data;
if( pfd == NULL )
error_code = -1;
goto RECORD_AU_QUIT;
error_code = -1;
do
error_code = -1;
save_cnt--;
SerialBook++;
else {
}else{
RECORD_AU_QUIT:
if( pfd )
fclose(pfd);
return error_code;
void Init_Interface(int Msg_id)
int qid;
if(ApproDrvInit(Msg_id))
exit(1);
if (func_get_mem(&qid))
ApproDrvExit();
exit(1);
void Clean_Interface(void)
ApproInterfaceExit();
long long GetDiskfreeSpace(const char *pDisk)
long long int freespace = 0;
struct statfs disk_statfs;
if( statfs(pDisk, &disk_statfs) >= 0 )
freespace = (((long long int)disk_statfs.f_bsize * (long long int)disk_statfs.f_bfree)/(long long int)1024);
return freespace;
long long int RESERVE_SPACE = 2*1024; //reserve RESERVE_SPACE kbytes for write tail
int CheckCardFreeSapce(void)
long long int freespace = GetDiskfreeSpace(pCurr_path);
if( freespace < RESERVE_SPACE )
fprintf(stderr,"Space = %ld Kbyte is not enough \n", (long)freespace);
return -1;
}else{
return 0;
void CheckReserveSpace(void)
fprintf(stderr,"Space on %s = %ld Kbyte \n", pCurr_path,(long)freespace);
if( freespace < 4*1024 )
else if( freespace < 8*1024 )
else if( freespace < 16*1024 )
else if( freespace < 32*1024 )
RESERVE_SPACE = 3*1024;
else if( freespace < 64*1024 )
RESERVE_SPACE = 5*1024;
else if( freespace < 128*1024 )
RESERVE_SPACE = 10*1024;
else if( freespace < 256*1024 )
else if( freespace < 512*1024 )
RESERVE_SPACE = 20*1024;
else if( freespace < 1024*1024 )
RESERVE_SPACE = 40*1024;
else if( freespace < 2048*1024 )
RESERVE_SPACE = 80*1024;
else if( freespace < 4096*1024 )
RESERVE_SPACE = 160*1024;
}else{
static void signalHandler(int signum)
fprintf(stderr,"AVI caught SIGTERM: shutting down\n");
AbortSignal = 1;
static void signalHandler_user1(int signum)
//fprintf(stderr,"AVI caught SIGUSER1: add time\n");
Pts_Addon_Duration += 10;
void init_signals(void)
struct sigaction sigAction;
sigAction.sa_flags = 0;
sigemptyset(&sigAction.sa_mask);
sigaddset(&sigAction.sa_mask, SIGINT);
sigaddset(&sigAction.sa_mask, SIGUSR1);
sigAction.sa_handler = signalHandler;
sigaction(SIGINT, &sigAction, NULL);
AbortSignal = 0;
sigAction.sa_handler = signalHandler_user1;
sigaction(SIGUSR1, &sigAction, NULL);
Pts_Addon_Duration = 0.5;
/* media file output */
int main(int argc, char **argv)
const char *filename;
const char *interval;
const char *msg_id;
const char *frame_rate;
const char *Is_Audio;
const char *pIs_chkcard;
const char *pStream_id;
AVOutputFormat *fmt;
AVFormatContext *oc;
AVStream *audio_st, *video_st;
double audio_pts, video_pts;
int STREAM_DURATION = 0;
//int STREAM_FRAME_RATE = 30;
int nMsg_id = 0;
int nIsAudio = 0;
int nIsChkcard = 0;
int i;
int audio_ret = 0;
int video_ret = 0;
/* initialize libavcodec, and register all codecs and formats */
av_register_all();
if (argc != 8) {
printf("usage: %s <output_file.avi> <interval> <msg_id> <frame_rate> <Is_audio> <Is_chkcard> <stream_id>\n", argv[0]);
exit(1);
filename = argv[1];
interval = argv[2];
msg_id = argv[3];
frame_rate = argv[4];
Is_Audio = argv[5];
pIs_chkcard = argv[6];
pStream_id = argv[7];
STREAM_DURATION = atoi(interval);
STREAM_FRAME_RATE = 30;//atoi(frame_rate);
nMsg_id = atoi(msg_id);
nIsAudio = atoi(Is_Audio);
nIsChkcard = atoi(pIs_chkcard);
STREAM_FRAME_ID = atoi(pStream_id);
fprintf(stderr, " FileNmae = %s interval = %d sec Msg_id = %d \n Is_audio = %d Is_chkcard = %d stream_id = %d\n",
filename,
STREAM_DURATION,
nMsg_id,
nIsAudio,
nIsChkcard,
STREAM_FRAME_ID);
if( STREAM_FRAME_ID < 0 || STREAM_FRAME_ID >= 2 )
fprintf(stderr, " stream_id = %d is invalide !!!\n", STREAM_FRAME_ID);
exit(1);
if( nIsChkcard == 1 )
pCurr_path = MMC_PATH;
}else{
CheckReserveSpace();
if( CheckCardFreeSapce() < 0)
exit(1);
init_signals();
/* auto detect the output format from the name. default is
mpeg. */
fmt = guess_format(NULL, filename, NULL);
if (!fmt) {
printf("Could not deduce output format from file extension: using MPEG.\n");
fmt = guess_format("mpeg", NULL, NULL);
if (!fmt) {
fprintf(stderr, "Could not find suitable output format\n");
exit(1);
Init_Interface(nMsg_id);
/* allocate the output media context */
oc = av_alloc_format_context();
if (!oc) {
fprintf(stderr, "Memory error\n");
exit(1);
oc->oformat = fmt;
snprintf(oc->filename, sizeof(oc->filename), "%s", filename);
/* add the audio and video streams using the default format codecs
and initialize the codecs */
video_st = NULL;
audio_st = NULL;
fmt->video_codec = CODEC_ID_MPEG4;
if( nIsAudio == 1 )
fmt->audio_codec = CODEC_ID_PCM_MULAW;
}else{
fmt->audio_codec = CODEC_ID_NONE;
if (fmt->video_codec != CODEC_ID_NONE) {
video_st = add_video_stream(oc, fmt->video_codec);
if (fmt->audio_codec != CODEC_ID_NONE) {
audio_st = add_audio_stream(oc, fmt->audio_codec);
/* set the output parameters (must be done even if no
parameters). */
if (av_set_parameters(oc, NULL) < 0) {
fprintf(stderr, "Invalid output format parameters\n");
exit(1);
dump_format(oc, 0, filename, 1);
/* now that all the parameters are set, we can open the audio and
video codecs and allocate the necessary encode buffers */
if (video_st)
open_video(oc, video_st);
if (audio_st)
open_audio(oc, audio_st);
/* open the output file, if needed */
if (!(fmt->flags & AVFMT_NOFILE)) {
if (url_fopen(&oc->pb, filename, URL_WRONLY) < 0) {
fprintf(stderr, "Could not open '%s'\n", filename);
exit(1);
/* write the stream header, if any */
av_write_header(oc);
WaitVideoStart();
while( AbortSignal == 0 ) {
/* compute current audio and video time */
if (audio_st)
audio_pts = (double)audio_st->pts.val * audio_st->time_base.num / audio_st->time_base.den;
else
audio_pts = 0.0;
if (video_st)
video_pts = (double)video_st->pts.val * video_st->time_base.num / video_st->time_base.den;
else
video_pts = 0.0;
if ((!audio_st || audio_pts >= (double)STREAM_DURATION+Pts_Addon_Duration) &&
(!video_st || video_pts >= (double)STREAM_DURATION+Pts_Addon_Duration))
break;
//if( nIsChkcard == 1 )
break;
video_ret = -1;
audio_ret = -1;
/* write interleaved audio and video frames */
if (!video_st || (video_st && audio_st && audio_pts < video_pts)) {
audio_ret = write_audio_frame(oc, audio_st);
} else {
video_ret = write_video_frame(oc, video_st);
if( video_ret < 0 && audio_ret < 0 )
usleep(5);
GetAudioInterface(NULL,NULL,NULL,1);
GetVideoInterface(NULL,NULL,NULL,NULL,1);
/* close each codec */
if (video_st)
close_video(oc, video_st);
if (audio_st)
close_audio(oc, audio_st);
/* write the trailer, if any */
av_write_trailer(oc);
/* free the streams */
for(i = 0; i < oc->nb_streams; i++) {
av_freep(&oc->streams[i]->codec);
av_freep(&oc->streams[i]);
/* close the output file */
url_fclose(oc->pb);
/* free the stream */
av_free(oc);
Clean_Interface();
return 0;
