dashingthrusnow
SP bitrate mod is in the firmware thread...
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
vibeone said:And for comparison, heres an older video I uploaded to youtube ages ago...
dashingthrusnow said:SP bitrate mod is in the firmware thread...
dashingthrusnow said:vibeone said:And for comparison, heres an older video I uploaded to youtube ages ago...
Notice an improvement in quality? I thought I did.. things look sharper with higher bitrate with less macroblocking!
ransoma22 said:I met with a problem.
I downloaded the modified firmware and tried to update, i heard the beep but after that, it stopped working.
The red led is lighted up but there no more beep, i try to reset the firmware back to 2.1 and it does not help.
Anyone facing the same problem as me and have some resolution to it ?
ransoma22 said:I downloaded the modified firmware and tried to update, i heard the beep but after that, it stopped working.
ransoma22 said:I downloaded from this link
http://dashcamtalk.com/cams/itb-100hd/itb100hdfw.bin
after the rapidshare link is dead.
What I could narrow down , which i am not too sure, could be i accidentally use a spare CLASS 2 *instead of the CLASS 10* SD card to flash it
Now i am trying all means to reflash back to original firmware.
Did re-formatting the SD card, press and hold ON/OFF MIC also does not work ..
Perhaps it time to rest this Itronics and buy a new one
mrkookm said:My ITB-100HD SP with the 12mbps firmware has been looping videos for about a 1½ days now with no issues. I'm using a Transcend 32mb Class 10 formatted with 64kb clusters if that makes a difference.
liujason said:I'm using the 100HD, and I also notice the problem of the device not deleting old files (I'm using an 8 GB SD card). Is there a fix for that?
liujason said:Another discovery - the mod is working overwriting the old files if it is powered all the time. However, once powered off, and power on, it will *beep beep beep*, complaining about the SD card. Only way to fix this at the time is to unplug the power, re-plug the power, wait for the ascending three beeps, and hold down the mic button for about 5 seconds to format the card.
So it seems the device complaint of the SD card problem only happens when the device is booted.
