The Batman
- Jul 24, 2019
- Canada
- Canada
- Viofo A129 Duo
Testing storage card
The one I have is the Samsung EVO Select memory card (the packaging says Made in Philippines). To verify the authenticity, I downloaded Samsung's Authentication Utility software. It passed but it only took seconds for it to check.
I read about H2testw but the storage card reader I have is quite slow so the write speed will be inaccurate. Should I still give it a try and what other tests should I run?
Glare
I installed the dashcam later in the evening as the sun was a bit lower and noticed a lot of glare in my videos. Would the CPL filter help in my case?
Front cam:
Rear cam:
Car adapter
I have the dashcam powered by the car adapter until I get it hardwired. Sometimes I noticed the car adapter's green light would go off causing my dashcam to turn off. When I twist it will sometimes turn back on. Did I get a faulty car adapter?
Also noticed that it takes about 2 or 3 minutes for the dashcam to power on when I start my car. I don't use car adapters so wonder if this delay is normal.
Thanks!
Glare
Front cam:
Rear cam:
Car adapter
Thanks!
