- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
I would be afraid that too large of a mirror will create blind spots
Or give you a cracking headache if you had an accident!I would be afraid that too large of a mirror will create blind spots
My wife would be all over that mirrorthat is by far the largest rearview mirror I have seen
Yes, I know. But as you can see it on my pictures, the unit is not so close as not located on the window but on the rear mirror instead. This makes distant between lens cam and windshield to be not less than 5.5" (14cm). Thickness of filter (mount included) is then no longer a challenge in my case. So, I wonder if an existing CPL filter (designed for another mark/model of dashcam) may suit this configuration (same diameter than my unit).
Thanks. Do you have such an item for sale?
As per my 1st post, 0806 cpl will not work in my personal set-up if using it as is without modifications. For your dashcam setup it may work if to attach permanently with double sided tape, but then it will not be removable if needed for night drivings. I need to replicate your dashcam set up and see how it works. Will try when get a chance.Hummm. I had a look on your CPL filters but diameter size seems to be greater than needed as designed for Panorama. I wonder if 24mm CPL designed for Mini0806 should be more suitable...
Good drawer ? [emoji4] Thanks, but its just a quick on the go solution to rephrase my earlier question.Yeah! What a good drawer you are!
Here it is the diagram with expected information:
But I do not understand difference between two magnetic CPL filters. And 36mm is twice big than necessary.
No problem.Ok. Thanks a lot for your help.
