Memory Card compatibility
just gone to the compatibility page, says sandisk extreme 128gb is unstable for 4K dashcams? below the 512gb sandisk extreme is listed as ok?
is this right? ive been running 512gb sandisk extreme in my 4k A229 Pro 3ch for ages with no problem??
ive been running 512gb sandisk extreme in my A229 Plus with 3 cams for ages with no problem??
or isnt the A229 plus a 4K?? just looking online and it appears not, i thought it was, too many options out there.
A229 Plus it's a relatively new cam. How could you have used it for "ages"?
And no, A229 Plus it's not 4K. A229 Pro it is. It's a little weird to not know the specs for your own dashcam.
Especially for a "well known member", no offense!
cant remember how long but a while and not a single issue.
i have that many of these things its easy to lose track of what one is what and where i have that many.
here it is attached.
it is 4K on the box it says.
Well, this is A229 Pro, not Plus as you stated in the first post.
A229 Pro Viofo began selling in the fall of 2023.
so this is a 4K camera??
Explain HOW you can use Sandisk Extreme 512 GB on 4k A229 Pro 3ch for many years without problems???
i didnt say years anywehere, i said for ages, since they were released pretty much, i cant even remember when that was, but i have had the same 512gb card in it since day 1 with no issues.
We do not mean the specific 128GB storage of this card is not stable, we mean the Sandisk Extreme Card is not so stable when used on our 4K cameras according to our experience.
What are your camera settings?
Is it used as 3 channels?
Is 4k selected as the resolution?
Is the image quality setting at maximum? Or which one do you prefer?
In fact, it cannot be called incompatible. Based on experience and experience, the answer to the question "you recommended this" is given in advance in case of a possible problem.
By the way, if the resolution is selected as 2k or FHD, it can work stably on 4k cameras. If the image quality is selected as low-medium, working conditions will improve and you will be able to use the card in question without any problems.
In summary, various problems may be encountered when using the (4k) cameras at full performance, but if reduced quality or resolution is selected in the settings, there may be no problem.
"This is pure conjecture."
Hi Friends, I am also getting same problem in recommending the compatible microSD to our VIOFO Customers in India. I gone thru all replies on thread relating to microSD but I couldn't find any suggestion which worked flawlessly in VIOFO A229 Pro 2CH/3CH.
There are so many well known as well as new brands are showing up on Amazon India with same A2,V30,U3 tech spec and size 512GB. Reviews and prices are as under:
1) Samsung Pro Ultimate 512GB : USD 68. 276 Revies. 4.5 Star.
2) HP MicroSD 512GB : USD 70. 10 Reviews. 4 Star.
3) Transcend 512GB : USD 48. 7754 Reviews. 4 Star.
4) SanDisk Gameplay 512GB : USD 53. 3 Reviews. 4.5 Star.
5) Lexar Play 512GB : USD 72. 4161 Reviews. 4.5 Star.
6) Gigastone Gaming Plus 512GB: USD 59. 10554 Reviews. 4.5 Star.
7) Gigastone 4K Camera Pro 512GB: USD 83. 2226 Reviews. 4.5 Star.
8) SP Silicon Power A1 512GB : USD 40. 996 Reviews. 4.5 Star
9) SP Silicon Power A2 512GB: USD 46. 3175 Reviews. 4.5 Star.
10) Amazon Basics 512GB: USD 45. 1062 Reviews. 4.5 Star.
So my humble request to @viofo and to all users/testers/sellers here to confirm whether they have used any of above card with VIOFO 4k Dashcam. Please share your experience.
The Samsung one sounds really tempting. I would like to know what makes the Viofo 512GB more suited compared to the Samsung one. Are the ratings not the whole story? Viofo doesn't share any tests, and telling people to buy a Viofo card is obviously very biased. The Samsung 512GB card can be bought for ~half the price of the Viofo one.
Samsung claims operating temperatures of -25 - 80 degrees C. That would be the biggest problem for dashcam storage, right? They're also waterproof, x-ray proof, magnet proof, drop proof, support 10k write cycles, 10 year limited warranty.
On paper the Viofo card is worse, since it's up to 100/90 MB/s read/write, and the Samsung is 200/130 respectively. The Viofo card works from -25 to 85 degrees C, so that's 5 degrees C higher.
Buy any memory card you like. No one can force you to buy something you don't like.
Viofo only recommends, and the choice is always yours.
Just don’t cry here that this half-price card can’t cope with three-stream recording and high bitrates.
I'm just stating facts to start a discussion. No need to be hostile because of that. The Viofo card gives a better feeling, which is most important in this case, but it's just that other cards have the same specs for less money. Would be nice if Viofo could share their test results so we can make up a balance for ourself. It's very easy for a manufacturer to say 'just buy our card because it is better'.
Read other posts, and search this form, as this question been asked many times before.
Far as i recall, the main thing is, Viofo claims their cards are made with "Industrial grade" flash memory. To which, it can withstand more harsh environment (ie the high heat of a hot car).
Additionally, are able to handle the higher workload of multi-channel dash cams.
Ratings might be the whole story, if you had all the information, but we never do. So a card that has a maximum temperature rating of 60°C might slow down a little when it reaches 60°C, slow down a little more at 80°C, but still be working fast enough when it reaches 100°C, while a card that has a maximum temperature rating of 80°C might slow down to unusable at 81°C.
Your actual experience with a card depends hugely on how you use it, what camera you put it in, what bitrates you have chosen in the settings, you climatic conditions, how/where you have mounted the camera, so it is not possible for Viofo to tell you which cards will work OK for you personally.
Viofo has tested some cards, and seen some cards cause problems for actual customers. They have given you some advice as a result. You can use that advice, or ignore it. They can't test every card in every climatic condition, you will not get better advice elsewhere.
For the Viofo card, they are described as Industrial Specification, which means that they should have a wider temperature range over which they work OK, and should have a longer life when used in normal conditions. I don't know how much longer, and Viofo choose not to give any specifications on lifetime, but in general you can expect an industrial spec card to work more reliable in higher temperatures and have double the lifetime. If it is double the price, that gives the same price per recording, plus better reliability. I can't say if that will be your experience, but that is what I expect. They are not standard consumer cards, built to be cheap and make maximum profit like the Samsung card is. Viofo make their money selling dashcams, not cards. I think they sell cards mainly in order to make their dashcams more reliable, for the people prepared to pay for reliability, and because it is hard to buy a decent industrial specification card at consumer prices.
We don't see many people having issues with Viofo cards, we do see plenty of people having issues with cards on Viofo's not recommended list. And when tested for speed in a fast card reader, the Viofo cards do outperform all the standard consumer cards, even the ones claiming to be fast!
I know, I've read it, but there are no hard numbers or anything else to back up their claims. The only difference I can see on paper is a 5 degrees C difference in temperature. All other manufacturers publish their IOPS and such, or write cycles. Since Viofo does not, it's just their claims we have to believe.
I've just ordered the Viofo 512GB card for 100 euro including shipping, so let's see how that performs.
Don't bother asking them to "prove" what they say... been down that road. Will get you nowhere. They do not have to prove anything.
People here will tell you they recommend their cards and the one on their list because of customer returns and support history.
Users here also have posted their experience with other cards as well, highly depends on the camera you use.
What i mentioned, is basically the best you are gonna get as far as hard information to explain why Viofo cards are "better".
Buy what you want. And see how it works for you. Personally, i have never had any issues with Samsung cards. However, i only use single channel Dash cams.
Fair enough. I've bought the Viofo one. I think peace of mind is more important than saving some cash. Time will tell.
That makes a big difference, for a 3 channel dashcam I highly recommend the Viofo cards, for a single channel, almost any card will work unless you live in a very hot place. My ancient Class 6 Samsung, bought when 16GB was huge, works fine in an A139 Pro, as long as it is single channel.
Some technologies may be used in the background of memory cards that not every user may know.
For example, MLC technology is used in the Viofo memory card. This makes the viofo memory card stand out. To give an example, a single-core computer and a 4-core computer will not be the same and will not be the same price.
So just speed doesn't mean everything.
In short, if you have time to spend, you need to do a little more research. If your time is valuable, you can directly buy a Viofo memory card and use it without hesitation.
Meanwhile, every technological product has the right to break down and cause problems. There is no guarantee that this will be completely problem-free, but it is guaranteed that if it breaks down within a certain period of time, it will be compensated.
Was I somewhere hostile?
Every Viofo topic raises the issue of memory cards. If you look into them, you can understand that memory cards work perfectly with single-channel models, have problems with dual-channel models and are not at all compatible with three-channel models. Therefore, Viofo's recommendations are based on user experience and complaints. But not all users voice the name of their memory cards unless they have problems with them. In addition, not all memory cards can be purchased in all regions. I have not tried 512GB memory cards, but GOODRAM IRDM memory cards of 64, 128 and 256GB work perfectly with Viofo models from v3 to A229 Pro 2CH.
This is not an advertisement. These memory cards work for me. 😎
Besides write speed, resistance to higher temperature is another parameter in SD card that is not important in normal use, but it is important in dshcam SD card.
It is the resistance to long-term repeated overwriting - therefore it is advisable to use cards specially specified for industrial use. They are always significantly more expensive.
There is no point in attempting some discussions and trying to make some savings. The SD card is not in our case for occasional hobby use
