Micro SD Card Question
I have had ZERO issues with Samsung SD card in dash cams. The 8yr old Evo cards i have been using in my old A119 V1 still work fine, and i use one of them in a Rpi4b for its OS and it still performs like new.
I also have had ZERO issues with a new Samsung Endurance 512GB card in my rear cam A119Mini2 set at 2K60fps.
However, as it has already been mentioned here, if you have a multi-channel dash cam, it is best practice to stick to Viofo recommended cards.
I will greatly disagree with Viofo on recommended Sandisk brand cards, over the years, personal experience, i have NEVER had a Sandisk micro-sd card, or usb stick or ssd, last very long, or not have issues and have very high fail rates. I do not trust Sandisk products. Never had a single Samsung flash memory product fail.
I also have an issue with Viofo chargeing such a high $ amount for their branded cards, and only offer a 1yr warranty. Other cards are 3 or 5yrs.
Also, i have repeatedly inquired of Viofo to publish/expand upon their so called "testing methods" and why they recommended certain specific cards, and all they replied with is from customer feedback/returned units/support requests.. etc... nothing that actually proves they ran any real tangible lab tests.
Viofo can charge whatever the market will bear, capitalism is legal.
Even in China.
Maybe this falls under “industrial trade secrets” they don’t owe you an explanation for anything.
If only we had an international organization for companies that came up with industry standards, practices, and minimum requirements for SD Cards.
Even in China.
Lol. what? Testing a sd card has nothing to due with trade secrets. If they claim that they tested them, then they should give a valid reason and proof, else, it is just false advertising/claims. Anyone can just posted "we tested this" and what does that mean though? And if users often have issues with the specific cards the manufacture says do not use, or it will give you issues, for all we know, they could have programmed the firmware of the camera to detect non-recommended cards and then purposefully degrade performance/reject them etc. (HP and their DRM like practices for their printers to only use HP OEM ink comes to mind.) I have already seen posts of users with Samsung(or xyz card) cards, that say camera gives slow card error, but speed tests externally prove the card is more than capable, the cam just not like that specific card for some reason.
And you stopped short on the $ thing, my main point is the warranty. That speaks wonders to many about how long they intend a product to last. They confident it will last 1yr, and after that, too bad, customer has to buy a new one. No thanks, not when their so called "not-recommended" products are more tan triple a warranty. I would be ok with the extra cost if Viofo was confident enough in their product to have a 5yr warranty on it, or longer than the established competition.
Those warranties are only 5yr if you don't use the cards much, Viofo's warrantee seems to by 1yr with unlimited usage!
Maybe that a UK thing then 😉. I have used other brand cards heavily, and no issues claiming warranty here in the USA. I have personally dealt with Sandisk, Luxar, Kingston sd card claims. (microcenter brand cards, they will just replace them right in the store, no questions asked, they tend to be a bit slow, or hybrid fast slow flash)
And, done warranty claims for various brands ssds/flash media that have failed in customers computers (when i worked in Computer repair) even ones that been used in DVR or CCTV setups etc.
(I personally have 5 older Samsung 2.5in SSDs in a couple home CCTV DVR systems, 2 commercial systems, and my home and parents Ubiquiti Protect NVR systems. Going on 6 yrs now, and all have at least 70% health left. ) As i keep saying, Samsung flash media i have had nothing but success with, even in DVR/Dashcam use. I have never had to claim warranty on a Samsung micro-sd card...they last longer than 5yrs, in my experience.
YMMV
Unfortunately, the card manufactures can and do change their manufacturing processes without any notice, so just because you tested one of their products does not mean a new one of what appears to be the same model bought today will have the same performance as the one tested one month ago.
The performance changes with use, a well used card will be slower, which makes test results fairly meaningless, unless you run your tests for the length of the 5yr warrantee, by which time they will have changed their production process 5 times and the results of the test will tell you nothing about newly manufactured cards.
The performance also changes with temperature, which means that different people will experience different performance, so the testing results will never match real life.
Keeping a list based on customer's actual problems and updating it regularly seems a very sensible way of dealing with the issue.
That be Sandisk right there! Since they were bought out by WD, Sandisk flash products been TRASH! I do have some old pre-WD Sandisk flash products, small and slow micro-sd, SD, and even some ancient usb sticks by them 2gb or less usb 2, and they still work fine. But modern Sandisk flash products, known to have issues, and they even got sued for it.
And, testing, well, LTT Labs and other third party peoples, working hard to do tests and reviews, to help prove companies claims. (there are sites to compare flash media, but yes user usage conditions will result in different results than ideal controlled lab tests. ) But that still does not excuse the vague and obvious "buy our brand card" and their "trust us bro" warranty. And for the cost of a Vifo card, i can buy 2x Samsung cards....so if it fails before warranty is up, then i got a instant replacement, file claim, and get replacement, and still have 2x cards on hand. Flash memory is pretty hardy thing, and is most often gonna fail very fast, due to defect, or not for a long time, if it is manufactured well.
And, plenty of users here, use xyz card in xyz camera, with no issues. Some others, have issues. Try it and see for your self.
Even in China.
Viofo sell to many markets, countries all around the world, but they don't seem to sell any memory cards in China! Not listed on their website:
How much should an industrial grade 512GB micro SD cost?
Hard to find a company that makes them that size, but if you scale up the price from smaller cards then Viofo cards are pretty good on $/bit.
@speedingcheetah
What do you think a fair price would be for Viofo Brand SD Cards?
Right now the current price on Amazon is;
256GB: $38 each (must buy 2)
512GB: $70 each (must buy 2)
What is "industrial grade" though? They seemed to have made that term up, marketing gimmick. Other brands say Pro, or Endurance or Extreme. The raw physical durability of sd cards, are pretty much very similar, some are more durable sure. But, I would not call use use in a consumer dash cam product "industrial" use. Not even commercial dash cam systems use drives labeled as "industrial" The raw flash in side xyz brand could be any of the very few actual flash manufactures, just have someone's brand label on it. Viofo does not actual design or manufacture their own flash.
@speedingcheetah
No idea really, again, "industrial" label is just marketing thing, same as Pro, Extreme, Max Pro Endurance, etc.
As i said, give them a 5yr warranty (at minimum) and i would be ok with current price, but if they truley are that good, then how about a 10yr warranty eh?
I have a few Samsung Pro model 2.5in ssds that have 10yr warranty. They were expensive. But still are going strong...
Where do you see the 1 year warranty for Viofo Brand SD Cards?
The only thing I can find is 3 months for accessories.
@speedingcheetah
I only paid $10 Maybe $15 i forget, for the Viofo 256GB "Industrial" card as it was with bundle Amazon had with the cam at the time. Probably was a sale or something. My 2nd cam purchase i just bought the cam only, and got Samsung card for free from another promotional credit thing i had from buying one of their ssds lately.
Oh really? Last i looked it was on Amazon. Damn.... That only justifies my opinion even more then, 3 months! WTF! 😵
Answered question on Amazon US, answered by the Manufacture it appears. I don't have the packing anymore to check if it states what warranty it on it.
Industrial memory cards use "mlc" technology and mean cards with greater durability and higher data protection.
For this, you can examine the slc tlc mlc card types.
Companies can use various names. ultimate, industrial, endurance..
No, the term is explained by the SD Card Association:
And what label a brand uses, varies, as other post shows. Pro Endurance / Industrial. Or whatever, product specs/design advertised to be used in harsh environments and in DVR/Dash cam... .so It should not matter what brand, as long as the card meets those specs. And, they do, but some folks still say their device gives card slow or issues. If that happens, it is a not up to spec card/defect or picky device with firmware that skews toward use of specific cards.
Pay the OEM brand name tax, the Viofo tax, the Apple tax, the Bose tax, Sonos tax...etc. Brand loyalty is a thing, so is that brands level of support, if you use their own brand accessory with it, then they will help you if issues arise (unless it is past their 3 month?? warranty) , if not, they always blame the other product.
Industrial grade means harsh conditions + long life time + consistent high speed, an Endurance card does not necessarily have long lifetime or consistency in speed.
Last time I looked into the Sandisk Endurance cards, the Viofo cards were rated for well over twice the lifetime in terms of write cycles. I haven't seen a specification for the current Viofo card lifetime, but I expect it is still twice that of Sandisk cards, otherwise Viofo wouldn't claim Industrial.
