richcam
- Oct 20, 2014
- United Kingdom
- 2x0801, 0806 (broken), Mobius 1, Mobius 2, Auto-Vox B60
I've seen videos like that when the computer can't play HD format as well so maybe check in another computer.
Nope, the video footage plays fine, the vertical lines are rolling as I turn the car, as in, that is what is being recorded by the camera.... But just in case Quick Time Player couldn't play it properly I also viewed the video in VLC which can pretty much play any type of video format that you can throw at it and the result was the same.
Sounds most like a faulty sensor chip to me. Hope you got it from somewhere easy to send back.
Luckily I purchased the 0806 from Combi whom are based in Leicestershire, I sent them an email with the bad news and Lee phoned me straight back, had a chat with me about what had happened and the steps I had taken to try and resolve the issue, then asked me to return the defective unit and would send me out a replacement by return. This is what is known as excellent after-sales service.
I've just done a test of the in-camera formatting on mine with the latest firmware and something has changed since I last tested it. It now formats correctly in exFAT format and records correctly to it, as I think you had said. I'm going to leave it formatted in exFAT to see if jokiin is correct that it will not loop, I'll post the results when the 64GB fills up...
It's interesting that you say that because I formatted the two 64GB cards in MS-DOS (FAT) on my Mac using Disk Utility and it performed flawlessly when in 1920 x 1080 resolution (except the quality wasn't good enough) so wonder if there is any benefit of using exFAT, like you say, it will be interesting to see if your card loops round when it's full, or whether it just stops recording as jokiin has suggested.
Once I receive the replacement 0806 dash cam I will try the 128GB class 10 card to see what happens - from what I can gather, the only thing holding back the use of larger memory cards is the pure expense of it.
