sorry i forgot to attach the link,Seems you received V.7.0.0.45 from ddpai support. Could you please upload the file for other users? Thank you!
Regards,
@B25SAN nobody here owes you a proof or a video to show you anything, so it helps yourself if you use more manners when asking. You might want to try using a phone-based WiFi analyzer to check, as I described earlier.
Bro, on YouTube it explains IF after he has successfully connected and connected to the DDPAI dascam. And the thing is, I can't connect to my android v10 device for the FIRST TIME. ONLY IOS THAT WORKED.@B25SAN nobody here owes you a proof or a video to show you anything, so it helps yourself if you use more manners when asking. You might want to try using a phone-based WiFi analyzer to check, as I described earlier.
try find in "ABOUT" in DDPAI app. it works.Seems you received V.7.0.0.45 from ddpai support. Could you please upload the file for other users? Thank you!
Regards,
Take a look and try to give your feedback.
Masalahnya sama gan, saya juga kemaren begitu, wifi gak kedetect sama samsung a71, email ke support ddpai, dikasih firmware terbaru, tp belum sempat dicoba karena udah dituker ke Viofo A129 Pro DuoBro, on YouTube it explains IF after he has successfully connected and connected to the DDPAI dascam. And the thing is, I can't connect to my android v10 device for the FIRST TIME. ONLY IOS THAT WORKED.
Oh gitu, ntar aku coba update deh. Tapi harus manual ya, bukan tinggal langsung dri aplikasi ?Masalahnya sama gan, saya juga kemaren begitu, wifi gak kedetect sama samsung a71, email ke support ddpai, dikasih firmware terbaru, tp belum sempat dicoba karena udah dituker ke Viofo A129 Pro Duo
Iya gan manual, file nya ada dipostingan sebelumnyaOh gitu, ntar aku coba update deh. Tapi harus manual ya, bukan tinggal langsung dri aplikasi ?
Thank you gan. Btw, pernah download hasil videonya di ponsel atau di pc gan ?Iya gan manual, file nya ada dipostingan sebelumnya
Please update the firmware.
1.Connect the dash cam with PC by USB cable. and PC will detect the camera as a USB device.
2.Download the attached update zip file,and unzip the file.
3.Copy the unzipped updated file into camera
4.Power on the camera, the camera will update automatically.
Durasinya videonya per 1 menit gan, saya buka dari memory nya langsungThank you gan. Btw, pernah download hasil videonya di ponsel atau di pc gan ?
Brp lama durasi videonya bisa didownload punya agan ?
Thanks for your reply, but I have sent my camera back to Amazon. It has too many issues, maybe I will write a little review compared to my Viofo 119V3. But at the moment I'm a bit short of time for that.try find in "ABOUT" in DDPAI app. it works.
I'm done. I don't know where it went wrong. In the link application that you informed, it only detects my home WIFI, the rest is not there. Even though my Dashcam DDPAI MINI 5 is on, the blue light is on, and can only be used via IOS. I have done everything I can.@B25SAN nobody here owes you a proof or a video to show you anything, so it helps yourself if you use more manners when asking. You might want to try using a phone-based WiFi analyzer to check, as I described earlier.
I have updated to v7.0.0.17 and it broke the USBSTORAGE gadget driver, which switches immediately to the UVC gadget driverNew Firmware is with ADAS is here
v7.0.0.15
