Dom D
- Jan 14, 2014
- Nevada
- Jado 169
I formatted the SD card as suggested, moved the .BIN file onto it, put the microSD back into the JADO and plugged it into the PC's USB port. The JADO turns on, then goes to a blue screen reading "USB CONNECTING" and it just stays there forever. I've tried multiple times but always get the same result.
The only thing I can think of is to rename the .BIN file. It's currently named "20131202-GPS-1CARD.bin".
do you have a wall charger like a iphone charger or similar? If so, try plugging the usb cord into that and plug it into a wall outlet and use that. I think if you connect the usb to a usb port a PC it initiazes a communication between the dash cam and pc instead of just supplying power. And yes, you need to rename the file to what the common filename for the firmware are. It should be in the info page for the mini 0801. I'll find the page for you
