@Tobi@s
Just curiously, Can I use on GPS+External model?
I saw file name it said 2 card. I don't have Internal memory.
Which version are you on at the moment?Thank you so much, but i have one problem.
My cam not recognize, I tried with all names.
I deleted all files, put .bin but when I call the update does not recognize
Tips ??
Thank you
Unfortunately this wont work. You'll get a misbehaving device.@Tobi@s
Thank you very much.
Thats the reason, yeah. Have you tried this one?Thank you very much.
it says "Invalid download token...." for Renault.
Also a problem with Honda logo. Switches to standby and stops recording a few minutes later. And does not turn off when stop the engine. My Mini has not internal memory. Reason is this?
Yes i tried it and was not problem.Thats the reason, yeah. Have you tried this one?
Yes you can, but you need a non-internal memory firmware
Interesting. Can you try to put bigger sd card than 8 GB as internal? For example 32.A short info after two days.
I have my cam from bought from Givoe - GPS + external and no internal with 20130926 sw.
I opened the cam and internal slot for SD was there. I added 8GB internal card and upgraded to 20131202. Worked fine for both int and ext card.
Now I used the custom version 20131230 (2cards with GPS) and as well everything is fine: gps works, both cards work, no stucking.
Same way? I mean you bought no internal memory Mini and open it and put 32 GB sd?32 internal works for me
Yeah, thats the problem. You should request it from your reseller![]()
Mini0801 Faulty LCD? | Mini 0801 | 0 | |
Fake Mini0801 internal views (red menus) | Mini 0801 | 39 | |
P | TS Version mini0801 Firmware Update from20130617 | Mini 0801 | 1 | |
Z | Mini0801 by Jado | Mini 0801 | 14 | |
Mini0801: First German reseller | Mini 0801 | 10 |
