ChpStcksRlz
- Dec 11, 2013
What is that camera? The menu doesn't look like a mini 0801
Interesting! Please take some sample shots. I'd love to see some night footage. It's a direct successor to our 0801's?
Is the mini 0801 GPS bracket compatible? (That way I don't need to buy another GPS model)
Does it also use mini-usb? Or is it now micro-usb?
So many questions, sorry
But it'd be a good device to let my tax return take a bite atthat way I'll have the 0801 in the back and 0803 in the front.
Last but not least, do you have a release date?
Wait, Jokiin does your company make the mini 0801?
So you can provide us a good place to buy and eliminate the copy of the copy that someone copied?no, I'm just working with someone else and giving them a hand with the product
I can certainly let you know who will have real onesSo you can provide us a good place to buy and eliminate the copy of the copy that someone copied?
Thanks, it's one of the things I most love about the Mobius. They make it easy to ensure you get a good productI can certainly let you know who will have real ones
Just tried it now.. Unfortunately it doesn't work. Long pressing up closes the menu. Long pressing ok takes a snapshot and Long pressing down doesnt result in any action.Not sure if it helps you work it out or not but this menu can operate with 3 buttons, up arrow to the top then long press up arrow to access the next menu option, this is how the A7 version of this camera is currently configured
I'm a bit out of ideas now... I do create valid rfs files (at least I can unpack them correctly using different unpackers from different developers) but I still get ARM exceptions when I try to boot after flashing the fs.Yes, it is possible in v0.2(not released yet). But you need the files as .pcm filetype.
Working everyday on it, almost finished the core functions, but I got one problem with building the FS section and I'm too cross eyed to find the faulty code... Maybe I'll solve that today
pget_mpl() failed in mw_mpl_get, available 13507304 required 0 Ercd = -17
gobj_load_fonts_rom: allocate fail
pget_mpl() failed in mw_mpl_get, available 12779600 required 227346044 Ercd = -17
gobj_load_one_strtable_rom: allocate fail
pget_mpl() failed in mw_mpl_get, available 196808 required 699040 Ercd = -50
gobj_load_bitmaps_rom: allocate fail
pget_mpl() failed in mw_mpl_get, available 196808 required 460864 Ercd = -50
@@@@@@ (VOUT-0 SW. Scalar) Remain HEAP_MPLID: 196808 @@@@@@
pget_mpl() failed in mw_mpl_get, available 196808 required 1843264 Ercd = -50
@@@@@@ (VOUT-0 OSD Buffer) Remain HEAP_MPLID: 196808 @@@@@@
--- ARM ABORT EXCEPTION ---
Oops: CPU Exception!
pc : [<c033be78>] lr : [<00000000>]
sp : c0421cec ip : 00000000 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : 00000000
r7 : 000002d0 r6 : 00000500 r5 : 001c2000
r4 : c04cdb98 r3 : 00000000 r2 : 00000000
r1 : 000e0fe0 r0 : 00000000
Flags: nzCv
IRQs on FIQs on Mode SVC_32
fonts.bin
length: 611094 0x00095316
offset: 6144 0x00001800
calcedend-1:617237 0x00096B15
paddingend: 618495 0x00096FFF
space: 1258 0x000004EA
bitmaps.bin
length: 597355 0x00091D6B
offset: 618496 0x00097000
calcedend-1:1215850 0x00128D6A
paddingend: 1216511 0x00128FFF
space: 661 0x00000295
strings.bin
length: 106968 0x0001A1D8
offset: 1216512 0x00129000
calcedend-1:1323479 0x001431D7
paddingend: 1325055 0x001437FF
space: 1576 0x00000628
xxxxx
offset: 1325056 0x00143800
bitmaps.offset - fonts.offset = 612352 0x00095800 <-total length
strings.offset - bitmaps.offset = 598016 0x00092000 <-total length
xxxxx.offset - strings.offset = 108544 0x0001A800 <-total length
