InToSSH
- Mar 26, 2019
- Czech Republic
Hello everyone,
recently I bought this dashcam, I am quite happy with it, and with video quality, but there are still some issues that are bugging me.
One of them is when I press the manual event record button, it only saves 5sec prior to the button press, this is not enough, for example if someone cuts into my lane, I need to control my car first, then press the button and I miss the moment they cut into my lane.
I would be happy if this could be changed in the firmware, not sure if this is related to the size of buffer in the camera, but I would be glad if it could save whole previous and current video file (which it already saves, split to 1min), this way it wouldn't need a buffer.
I am not quite familiar with how those firmwares work, or if this could be done, but being a PC software developer I was able to dig out some interesting stuff from the firmware, someone might find it useful.
If you connect the camera to the PC, you can do multiples things with it:
At least for me, the camera provides a DHCP for the 192.72.1.0/24 subnet. Based on what I have seen in the firmware, this seems to be hard coded in there, so it should be the same for all.
These links might also work for other MiVue models.
Preview live RTSP feed from the camera
Using for example VLC player you can view the live feed using these addresses:
Basic WEB UI for built in Alpha Imaging Technology Corp controller - can set WIFI settings and basic cam settings
Get the entire config from the camera (with config options list)
Set the configuration of the camera
Full configuration file: https://pastebin.com/iQmqq0y5
rtsp://192.72.1.1/liveRTSP/av2
(front)rtsp://192.72.1.1/liveRTSP/av4
(front)rtsp://192.72.1.1/liveRTSP/av1
(haven't had the rear cam connected, but I assume these are for the rear cam)rtsp://192.72.1.1/liveRTSP/av3
(rear cam?)Basic WEB UI for built in Alpha Imaging Technology Corp controller - can set WIFI settings and basic cam settings
http://192.72.1.1/index.html
http://192.72.1.1/cgi-bin/Config.cgi?action=get&property=*
http://192.72.1.1/cgi-bin/Config.cgi?action=set&property={PROPERTY FROM THE LIST}&value={VALUE FROM THE OPTIONS}
