Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
I've just moved my Mobius B lens to the back of my car to make way for the Mini 0803 at the front (for the time being at least). The timing of your post re. using 'Cloudy' WB setting was great, as my car has a dark tinted rear window. Suffice to say I am now using that setting on my rear mounted Mobius B, thank you!
Setting the WB (White Balance) to "Cloudy" doesn't really do anything to effect the exposure of an image, it basically shifts the color temperature (color cast) more to the yellow and away from blue. (opposites on the RGB color chart) On a cloudy day this setting will make a scene look warmer and more pleasing. If you want to compensate for a dark tinted windscreen you really need to increase the exposure as Russ suggests. Trial & error is usually the best method to arrive at the optimum setting.
To see an excellent example of the difference between an "auto" white balance setting switched to a warmer "Cloudy" setting see this LINK. Ken Rockwell offers a good explanation of how white balance works.
