anthillmob
- Dec 1, 2014
- United Kingdom
I had a very similar problem to the OP's (I posted about it in that mega-long sticky support thread on this sub-forum). I had two cameras, two identical setups in two cars (I mean IDENTICAL - same cables from the vendor, same USB adaptor, same SD cards, same 2.25 firmware etc).
The 'good' camera worked fine in both cars. The 'bad' camera would not auto-start consistently in either car, and got progressively worse & worse. It also became progressively harder to start on the button. Having started with difficulty for the first time each day, it was generally OK the rest of the day. I tried swapping the SD cards, and trying an alternative, before you ask.
I ended up sending it back, haven't received a replacement yet. Interesting to see a spate of similar complaints from others...
I've just this morning received a newly-ordered Mobius for the back window & I'm really hoping this one does not have the same problem. It'd be utterly impractical to manually start a camera mounted back there.
