I purchased the same Small Rig cheese plate to use with the same ball joint mount so that I can run my M1 with 6-22mm ƒ/1.6 varifocal side by side with the Maxi and ƒ/1.5 Lens B lens. However, instead of using VHB tape to mount the camera to the cheeseboard I use 3M Dual-Lock Tape. This provides the ability to
securely mount and adjust either camera forwards or backwards to compensate for each camera's coverage so that the longer varifocal lens doesn't end up in the FOV of the Maxi. To a certain extent you can also adjust the horizontal lateral angle of each camera left or right using Dual Lock tape. Of course, having the ability to securely mount and unmount cams to the cheeseboard at will is much easier than to having to contend with VHB tape. For example, you don't need to re-adjust the chesse plate orientation each time you remount the cameras.
With the Maxi, I apply the tape directly to the bottom of the camera, thus eliminating the cradle. With the M1, I keep a spare cradle on hand with Dual-Lock on the bottom that I've had in service for various projects for several years now. (like my baseball cap cam)
