Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
Half my cams use suction mounts in the work van; no A/C, hot humid summers, mild winters, mid-grade mounts. On windows exposed to sun I get 2-4 weeks. On side windows that are less exposed I get 3-6 weeks. On the painted metal above the window, never exposed to sunlight, I get 4-8 weeks. A clean surface on both sides is critical, and a bit of spit on the edges of the cup seems to work best so far. Water doesn't do half as well for me, and the same for greases and oils.Judging by the residue, my guess is that the spit hardens into any voids, then stays there while everything else remains viscous and eventually moves, breaking the seal. And I've never figured out the time-spread mentioned above, even when I do everything exactly the same there is a 100% variation regardless of weather. Residue clean-up is a beach though. Remembering the "barbecued Buick", it was a 2/3 to 2 week mounting, but that windshield got really hot sitting in the sun. I don't remember seeing it fall off in the fire though but it might have.
(added) I think every cam should be supplied with both suction and permanent mounts, or at least letting the customer choose which one they want.
Your time frames sound about right for suction cup holding longevity although in my experience there can often be unexpected failures. Part of the equation is that I often drive on (depending on the time of year and weather conditions) very bumpy rural dirt roads like the one I live on. Of course, living in New England I get to deal with extreme sub zero temperatures which silicone suction mounts don't seem to like very much. In fact, once a suction mount falls off in sub-zero temperatures you can pretty much forget about remounting it until things warm up quite a bit and even then it still may not stay on the glass too long.
