I wonder if mobius deviated from the mp4 specs or if many apps are not able to handle these large video files especially on older computers. If the mp4 standard was badly implemented a firmware change can fix that problem.It's a shame about the compatibility. I can only conclude, Mobius appear to have deviated from the standard MP4 specs.
As for my impressions.... I was a little disappointed at how bad retrieval was in the light dusk though as there was comparatively quite a bit of light around. (T)here's another slight app / instruction issue, there are no instructions for updating firmware when you have caps fitted instead of a battery. Another thing to beware of, is when the camera is 1st connected to a USB power supply, it goes into mass storage mode which then causes it not to show in the Mobius app. it's not intuitive as you have to see the message between the mobius camera screen and settings screen and then press the 2nd half of the message to get up an instruction box containing the solution instruction.
Overall though, plate retrieval at dusk / dark aside, 1st impressions are this is going to be one of the best pictures out there.
I found that even at quite light dusk, although the video quality looked good, number plates were blurred and pretty much irretrievable. Obviously this got worse as it got darker.
What Mobius website?? They don't have one.The more surprising issue though was how the card test app from the Mobius website left the card un-formattable in the PC and caused Windows Explorer to restart, That was the real issue.
I think Dirkzelf their advertising is probably correct in those circumstances as in crawling to stationary traffic as show above, there's no movement so little blur from a slow shutter. Also, by and large all of those plates are shot from almost straight behind which helps greatly. The issue with shutter blur blur is more prominent where there's movement of each vehicle in different directions relative to each other at speed as then there's more movement at the end of the frame relative to the position of the capture at the start.
As I can't put up edit the videos atm, here's a still from mine at light dusk - you can also see this illustrated in the stationary cars - their plates are sharp in the distance as there's little relative change in position, but the van that's almost next to me and moving is totally blurred out - classic signs of slow shutter being the cause here in my opinion. Both vehicles were doing around 20mph.
Sunset time was 19.32pm Recorded time was 19.21pm so 11 minutes before sundown:
Other than that, it's hard to tell from the stills because of the individual frame blur, but the pictures otherwise look very nice. In this one taken a couple of minutes later (so nearer to dark), you can see the bollard straight ahead looks quite crisp considering the slow shutter (obviously very little movement relative to the vehicle, but it indicates what the camera will probably deliver in better lighting.
If it can be quite crisp with a slow shutter, imagine with a faster one).
There's nice saturation. There appears to be detail in the trees and grass, albeit they're blurred because of the slow shutter and movement once more. However, the detail appears to be there. I imagine (still to be tested) in much better daylight conditions, the picture it going to be rather good and probably one of the very best. It doesn't look bad as video instead of stills even in these lo light conditions. Only caveat to this is what effect reducing from extreme fine to fine will have on the picture.
I know all of what you are saying above. There's just the illusion created by the seller to make the buyer convincing himself "that's what I want"!!
I've been years in sales and marketing, and I know the tricks when I see one... Nevertheless it's the buyer him or herself to decide what's what, and I believe new buyers to dashcams may be lead to believe that this camera sees all license plates even in the dark hours, just by viewing the nice pictures. It would be more honest to show a real video, instead of some still pictures.
The sad thing is that all of us here know what we are looking at but the average consumer doesn't have the knowledge or experience to know just how misleading those images are.
I am using a twin Maxi setup for testing. One with the F1.5 Lens B, the other with an F1.6 6-22mm varifocal lens. The A129 has an IMX291 sensor and an F1.6 lens (which looks identical to the Maxi Lens B) so it could provide some interesting comparisons.
This screen mount:PS: Can you tell / show us more about that mount??!?! seems nice, magnets?
