SawMaster
- Apr 10, 2015
- SC
- Numerous and ever-changing
I like tinkering with electronics and still use my three Mobius. All three have survived all of the previous mentioned "running repairs". But not all people have the knowledge/ skills/ time to pull a Mobius apart, fit a super cap, hard wire it to a vehicle and then work out why it may not be recording automatically due to that specific vehicle's electrical system.
Anyone can fit supercaps to Mobius, all you need is a small #0 Phillips screwdriver to open the case. The battery or caps are a simple plug-in on the PCB. My 9 year old nephew could do it without guidance or assistance and he's not mechanically inclined. And it's not Mobius fault that you weren't giving it a good power source- it takes the same 5V mini-USB input that most cams do- so you should know better than to blame the cam when the power source is the problem. Mobius doesn't come with a PS though some sellers will offer a package deal including one; if the offered PS isn't up to snuff the blame the seller. Mine was still recording when I left the lights on and ran the battery down to where the starter solenoid wouldn't click- that's about 10V or less in my decades of experience with vehicles like mine. I use an Anker dual-port PS and like Mobius it never gives trouble. Mobius has over-voltage protection to save the cam should the PS lose regulation where most cams would just turn into a smoking brick of toasted electronics if that happened. Use at least a 1.5A PS of decent quality along with good USB cables and you shouldn't have a problem; that is the same for all the USB-powered cams and not just Mobius. Fail that and most cams will give erratic operation if they will work at all.
As to the melted case, mine has been through several days in a closed van where that air temp was 38C or a little more (over 100F) outside and it was noticeably hotter inside. There are people here who've posted pics of other cams which warped in heat like that but my Mobius didn't. And even then, if your case gets damaged with almost every other cam you're screwed because parts aren't available, but with Mobius a new case is available cheap and fairly easy to swap out using only that #0 Phillips screwdriver I mentioned earlier. With the heat in Adelaide's summers many cams would be turned into globs of non-functioning plastic with the electronic components unable to withstand it and dying along with the case. A Mobius equipped with supercaps is well known as the most heat-resistant cams on the market. The only problem I ever had with mine is when the original battery swelled it's first summer yet even then the cam kept working until my supercaps arrived.
I can't see why you attribute problems to the cam when it's obviously not the cam's fault. And I can't see why you don't understand that your summers are generally hotter than most, same as mine (in fact almost exactly the same as far as temps), reaching heat levels which would be beyond many aftermarket electronics ability to withstand. I've had GPS units, Ham radios, CB radios, other dashcams, and several other electronic gadgets fail to function in the summer heat here until they were cooled down and I've watched many plastics turn to goo in our summer sun, yet my Mobius keeps going even when touching the heat sink almost instantly burns my heavily calloused fingers.
Murcod, your experiences are so far from the norm that I wonder what's going on that makes it so. Either you're doing something wrong or your luck is worse than mine, and mine is pretty darn bad.
