Mount to Cam Magnet
Andrew Clough
Jeez that's a strongun!
Is there any easier way to detach the cam from the mount without having to re position the cam when you re attach it the next time after the struggle?
Tony lovelock
Hampshire
Nextbase 422gw/Nextbase 212G & möbius C3 wide angle lens
Unfortunately not, I think the 312, 412 etc were a lot easier to mount/dis mount as it slid on & off
Kremmen
West London & Reading
Viofo A119 V3
..... and even then it was impossible to dismount mount without having to realign
A
Andrew Clough
Ah well, thanks for the replies, I was hoping there would be some 'knack' to it.
At least it's easy to re align it and the mount doesn't wobble about all over the shop like the 612GW did.
Rickn55
England
Nextbase 612 4k, 522+rear window cam, 322+rear view cam, 312
This is one of the reasons why I've gone back to using my 612 up front and 312 at the rear, they're so much easier to remove when parked up.
geordiejohn
London
Hello I have just had one fitted at Halfords and the fitter said when you get home charge it for 2 hours but I can't get the camera off?
Nextbase 322 gw
Thank you.
Tony lovelock
Hampshire
Unfortunately you have to put a little bit of force behind the camera/mount when dis mounting takes abit of practice lol
Rickn55
England
Nextbase 322 gw
Thank you.
Hold onto the windscreen part of the mount whilst you pull the Dashcam itself with the other hand and it will just come free.
geordiejohn
London
Thank you all I will try tomorrow and post back if I get it off.
A
Andrew Clough
Ha Ha! At least it's not just me then :)
Given how hard it is to get off I may just leave it in there to be honest unless it's going to be parked up for an extended period when I can't keep an eye on it.
Rickn55
England
Why the 2 series Dashcam and mount sit and look massively more modern on the windscreen than the old 1 series, I still prefer the 1 series cams and mounts, so much easier to remove. Guess if you leave it in permanent this isn't an issue.
A
Andrew Clough
Yes, I think with the new lower profile mount as well it's less noticeable - so only can be seen if you are specifically looking for it.
Even then I think if an opportunistic thief tried to take it off they would give it a quick tug and think the mount and cam are all one unit fixed to the windscreen and give up.
Given that I use a Disclock Steering wheel device that stands out like a sore thumb I guess the bad guys tend to see that and move on to easier targets anyway.
H 322GW 19
EvilPraetorian 322GW 24
